Question about Dryers
My Whirlpool dryer has no high heat anymore.
Mod#GGQ8858HQO.High heat no longer works. Do you know why?
  • philippahugh Nov 03, 2008
    High heat setting only gets warm now and so drying takes ages. What is wrong?
  • 156 Answers
Ck the switch for heat selection
Posted on Mar 02, 2008
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
Whirlpool Dryer LET7848A - no HIGH heat
yes the coils which heat the heater heating plates are faulty because of broken wire.
they hshould be replaced to make it work.
thanks.
Sep 21, 2008 | Whirlpool Dryers
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Our Whirlpool dryer GGQ8831 dries too hot, even on the extra low setting. I do not use the sensor to dry clothes anymore, either. We don't know if it's due to the ductwork (possible inadequate air flow) or...
You most likely need to replace the cycling thermostat located on you duct inside the dryer. If you continue to use like it is, the high limit will end up going out. When it does the dryer will stop working al together. There are two that you need. If you go to parts select.com. enter your model #. It will bring you unit up. Click on Bulkhead parts picture on right. you will need part number 42 and 43. These are cycling thermostats. One is a lower heat and the other is the medium and high heat. what you running on at this time is the thermal cut off. When is goes bad it will put the thermal fuse out, cutting the whole machine off. I hope this helps. No to worry, these are common parts that go out from time to time.
Oct 10, 2009 | Whirlpool Dryers
Dryer does not dry as fast as it used too. Takes two cycles to dry a big load. Filters and exhaust are clear, and blower is still blowing. Looking in heat element, seems like botton 1/3 of coils don't turn...
Then part of the heating element is most likely not working because it is burned out or the high heat setting on the control no longer functions. Let me know the model number located most times inside the door on the wall of the door opening. That way I can Help you better, Thanks, Sea Breeze
Jul 13, 2009 | Whirlpool Dryers
Dryer is working but not heating
There is a heating element which can be replaced but first check the home's electrical fuse panel or reset the breaker even if it doesn't look like it tripped.
If you have 240V going to the dryer and still no heat it could be either the element, thermostats, timer or wiring.
Whether it's worth the trouble depends on the age of the dryer and your investment of time and money. None of those parts would take longer than an hour to replace. If you want to tackle it let me know and I could try to guide you through it.
Feb 19, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
287 people viewed this question
Top Dryers Experts
Marvin
Marvin
