Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 harddrive broken
The green light is no longer flashing at the front. I believe that i put in the wrong power supply. I realised it would cost me £100 to recover my data and this is £100 i do not have. I have bought an enclosure as i believe this is the problem. Can you help me to firstly connect the enclosure to the hardrive. thank you
  • Arturocc Mar 03, 2008
    mine is the smae it was working fine lst night but today the green light is only flashing and is not steady, my bet is that is fied or the powers is not right, cos i am on south america at the mo, but all my data is in there and i need to get access so what can i do? is there a way i can look at it my self? and what should i look for? many thanks
  • spyder1 Mar 15, 2008
    i have two external hard drives both of different makes and i by mistake one day pluged in the wrong power lead and turned it on to find that i had blown something inside the unit so i bought an external hd encloser hoping that this would cure the problem but it didnt so now i know the problem is in the hard drive,is there any way or any one that can retreve my data back off it.im totally heart broken as i have many digital photos of my father who has sadly now passed away,i pray they are not lost so any help i would be most greatful
    Novelist:
  • 104 Answers
First thing First, detect and isolate the problem:
take the HD and connect it to the computer (DATA AND POWER CABLES right connected) and see if Operative System detects it and you can partition, format and write and move data to and inside it without problems.
If you can and the system works OK with that... your HD is working so take a breath. If not... you HD is down and well... there is not much to do without expending money.
If you succeed, just try powering your case without the HD and of course with the right power supply... the one that comes with the case. if the case can be powered for a few hours with no problems nor rare noises... connect the HD to it and try.
The info you are giving is very incomplete, I don`t know what you did, what system are you operating, Do not know what you know about computers, so I do not know what to explain and what you know already.
Good Luck
Posted on Mar 10, 2008
What does blinking green light on Maxtor 3200 mean?
Typically, if your seeing that green light, it means you don't have enough power from your power supply. You may need to disconnect some of the other components for the drive to boot up. Ultimately, if you want to continue using the new drive, you'll need to replace out the power supply with a larger one.
Good Luck
Sep 07, 2014 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200 has a gren light that is now blinking and the computer cannot start the drive. Code 10. What does this mean?
I had this problem. I learned that the power supply was defective. You can purchase a 12V 2amp power supply. This solved my problem. My green light was coming on but my computer didn't recognize the drive and I got the same Code 10 cannot start drive. I purchased a 12V 3amp power supply. It doesn't hurt to have more amps but you need at least 2amps.
Jan 08, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Wrong power supply used with a maxtor external hard drive
You could buy another drive with the same specs and replace the circut underneath the drive with the circut from the new drive, then try it in your new enclosure
Jun 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
HD not spinning
Hey guys I had the same problem... All the drivers for the device are inside the harddrive. Maxtor doesn't have any because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Apr 22, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 usb hard drive with windows vista home premium
Jan 29, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
Dec 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
Aug 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 power supply problem
I plugged a HP laptop charger into the drive and all it did was flash, bought a new housing and no luck. Data recovery sites said that it sounded like hardware trouble and the recovery minimum is $800. I did some more searching and found a site called PCB Solutions that sells the circuit board. You have to provide all of the specs. for the drive. The cost was $39 and I received it in 4 days. I replaced the board and the drive worked and I recovered all of my data. The URL is:
http://www.onepcbsolution.com
Nov 09, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
163 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
