Washing Machines Logo
Posted on Feb 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAMSUNG WASHING MACHINE WF306LAW
An error code upside down Fand E shows water temperture problem. Washer starts briefly than stops with error code.
  • kened Feb 29, 2008
    First is an upside down F and E.
    Like LE but the L would be the F.
  • Anonymous Mar 29, 2014
    the machine counts down but those not start ?
isaac johny
Level 3:
  • Master 796 Answers
  • Posted on Feb 29, 2008
isaac johny
Master
Level 3:
Answers
796
Questions
8
Helped
241641
Points
2011
Is that the error code??
  • isaac johny
    isaac johny Feb 29, 2008
    may be the theromostat is not performing better...
    did you see it??
Samsung front load washing machine 5E Error code
If your Samsung washer is in the middle of a drain cycle and the 5E error code shows on your washers display, it means that the water is not properly draining out of the washer. Something may be clogged, jammed, or blocked and thus preventing water from draining out of the washer.
https://removeandreplace.com/2016/11/03/samsung-washer-displays-error-code-5e-message-how-to-clear-error/
Samsung wf306law/xaa Had a ND code. drained lines, pump etc. But won't Spin, nor do i get a error code.
If all of the water has been drained from the washer, check the hose to the water level sensor is not plugged. You can find information on the nd error code here
https://appliancerepairinfo.com/samsung-washing-machine-nd-code/
2answers
I have probelm in my Samsung washing machine WF-B1061
NF and 4E = No Water Feed = Washer Not Filling. This means that there is an issue that is preventing your washer from receiving water into the water inlet valve. The troubleshooting steps below apply to all types of Samsung washing machines including front load, top load, and washer and dryer combos
https://removeandreplace.com/2015/12/16/samsung-washing-machine-shows-nf-or-4e-error-code-what-does-this-fault-code-mean
2answers
Shows code upside down f and a 3
Take a look at these codes and see if any look similar.
Sometimes the digital read-out looks different from printed type.
Down on the page there is a link to explore older codes Samsung Washing Machine Errors eHow
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
1helpful
2answers
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Washer fills up with way too much water.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
F21 showing on screen
Take the bottom panel off of the washer and there should be a instruction guide in the washer that will tell you what the error code indicates.
1helpful
4answers
Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Top Washing Machines Experts
john h
