Question about Panasonic KX-FL511 Plain Paper Laser Fax
Paper Size If someone is faxing a legal size document, and I want it to come to my fax machine on legal size paper without shrinking the data on the paper, how can I do so?
  • jhamilton Mar 10, 2008
    I did change the paper to legal size, checked the options, and looked in the book. No where could I find that option, if you do please help. Thanks for your time.
  • 168 Answers
Have you tried placing legal size paper in your machine?
Also check the user settings. I am pretty sure there is an option to shut down the automatic reduction for legal size paper.
Check your user manaul if you still have it. If not, then let me know and I will see if I can look it up for you.
Good luck.
Mac
Posted on Feb 29, 2008
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Sending and receiving fax on legal size paper on
What's the question? You can send a fax on legal size exactly as you do with lettersize. As for printing, you only have 1 size of paper available at a time (1 paper source) , so put legal in it if you want.
Apr 12, 2009 | HP LaserJet 3050 Printer
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
May 11, 2008 | Office Equipment & Supplies
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
143 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
