Nakamichi RE-2 receiver turns on, but when connected to speakers nothing happens, on the screen in a little box it says locked, dont know what that means??
  • 71 Answers
Could have got itself in a 'logic knot' . Try a complete reset ( i.e. switch off at mains , connect speakers first , switch on after a good 30secs. 'off' period and go through the initial settig-up procedure as given in the handbook.
Good luck.
Posted on Mar 11, 2008
Subwoofers Power Cable and Speaker Connecting Cables
Nothing special about the original Nakamichi cables. Brochure here:
Nakamichi Soundspace 12
Jul 14, 2016 | Nakamichi SoundSpace 12 System
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
May 07, 2014 | Yamaha RX-V995 Receiver
I have the nakamichi re 1. One of the speakers is playing much lower than the other. This is consistent with the headphones also. Any ideas? Thank you
Does this problem happen on only one input, or on all inputs?
Either way, the problem is in the preamp circuitry as it happens with the headphones & speakers. Unfortunately this would be a repair for a professional.
Mar 15, 2011 | Nakamichi RE-1 Receiver
After the recent purchase and professional installation of a used Nakamichi CD 700, I noticed my front speakers weren't working. Activating the fader adjust I noticed that when I turned the knob...
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
http://www.nakamichi.com/home.html
Sep 05, 2009 | Nakamichi Audio Players & Recorders
Nakamichi AV10. Re: left channel softer than the right one.
Hi,\
Its an issue with the tone switch activate and reactivate it to get back to normal volume on both speakers, and would suggest you to clean the switch with WD40 and it should resolve the issue
Jul 16, 2009 | Nakamichi AV-10 Receiver
Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Aug 03, 2008 | Audio Players & Recorders
Philips digital audio/video surround receiver FR965/17
same here ,men , i start the tearing apart hehehe, and i think it can be one the little chip located behind the control panel so i remove the white ribbon, the one looking like an ide connector for a hard drive, and guess what it turns on, but when you connect the ribbon just goes back to stand by mode, maybe requires a flash on one of the little chips, same thing happen to a lap top that i use to have, just shorted 2 of the pins and start working normally, im gonna find more info but there sems to be nothing about this amp, high five from mexico men
May 13, 2008 | Philips FR965DHT Receiver
Nakamichi AV-10 loud thud from subwoofer
I don't know the design of this reciever, and do not have any schematics or engineering information to know the design.
This is a general comment:
In many of these recievers at this level they don't have very good muting designed in to their system. When switching sources, the audio is not being muted.
This is a theory of why the noise is not on the main speakers, but present on the sub woofer. Because the switching noise is of very low frequency, this is why the sub woofer is making noise. The main speakers lack the low frequency sensitivity that the sub woofer has. This is one way of looking at it. It is also possible that there is muting for the main speakers, and none for the sub woofer.
If the reciever does have muting in to its design that is supposed to mute when switching modes, then there is an obvious defect. When a source is switched, or a mode is changed, the output would mute for the duration of the switching interval. This is usually for a period of about 100 ms.
Your best bet is to contact the service rep for nakamichi and ask the question there.
I have serviced many recievers made by other manufactures. The higher end models all had muting in their design. This way, the output was muted when the source was changed, and when the reciever was turned off or on.
Jerry G.
Apr 23, 2008 | Nakamichi AV-10 Receiver
Nakamichi AV-10 very little sound on the center speaker
could be the speaker, try connecting another speaker and cable and see if it improves. If the problem is still there and you've checked all the settings insuring that its not turned down, then could be an internal problem with the receiver.
Hope this helps a little at least.
Mar 30, 2008 | Nakamichi AV-10 Receiver
Nakamichi receiver AV500
Did you make sure your Speaker A or B switch is pushed in? This happened to me a few times where I thought the receiver was broke, but someone had accidentally turned of the speaker A switch...
Dec 11, 2007 | Audio Players & Recorders
367 people viewed this question
 Grubhead
Grubhead
