Question about Memorex MT2245 TV
Memorex remote control
Cannot enter more than one didget when changing channels.
Have you tried pressing the TV/CATV on the actual set itself or going into the menu and changing the signal input to Cable or Air?
Posted on Aug 13, 2008
Memorex blu ray dvd play says no card
I was able to fix the 'NoCard" error on the Memorex 2520. On the remote control, find the "popup menu" button. This is located on the right hand side of the remote, above the pause and below right of the enter button. This button reveals a "change drive" menu. Highlight 'BD', press enter and you will be done. I am assuming that someone mistakenly changed the drive previously to "SD Card".
Mar 29, 2012 | Memorex MVD2050-BLK DVD Player
What are the setup codes for a 20' Memorex.
Three digit universal remote codes for Memorex are: 000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit universal remote code for Memorex are: 0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 01, 2011 | Televison & Video
RC00013 remote, channel change and power not working, how to fix?
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
Feb 27, 2010 | One For All URC-4605 Remote Control
I have a Memorex TV/DVD and can not find the remote control.  I can't seem to change channels without it.  When I manually push the channel button, it does not respond.  I can increase and decrease the...
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Nov 07, 2017 | Memorex MVD2113 13 in. TV/DVD Combo
4 didget remote code zenith
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0039 0001 0058
Oct 27, 2008 | Radio Shack 3-in-1 Easy-to-Use Universal...
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Jul 13, 2008 | Memorex MT2206 TV
Tv remote needed
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Memorex TVs. I bought it at Walmart for less than 10 dollars.
If you want to pay a little more money, here are a few websites to visit: REMOTES.COM 1-800-REMOTES
You can find a few more websites by typing in:
MEMOREX TV REMOTES into the Google searchbox.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, but using the rating system below. Thanks.
Jul 11, 2008 | Memorex MT1194 19" TV
Philips Universal Remote SRU2103WM/17
Try this:
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 02, 2008 | Philips Magnavox Learning Universal Remote
Memorex tv programming
I am trying to start remote ucr3110B00 on memorex MT 1120A please help me.
Dec 08, 2007 | Memorex MT2206 TV
Memorex MT2245 TV Logo
176 people viewed this question
Top Memorex Televison & Video Experts
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
