Question about Motorola Radio Communications
My 710 headset comes on with the blue light, but it isn't connected to my phone. When I try to connect by using "tools" in my phone, the connection fails. (The 710 was connected to my phone until yesterday - don't know the reason that it isn't now) My phone is a Samsung Alias.
The problem is fixed, but I'm not sure how! I tried again yesterday, and it connected.
Posted on Feb 25, 2010
SOURCE:
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Htc hero not pairing with plantronicc voyager pro. Is serching but not finding headset
Thanks for visiting FixYa!
How to Pair Your Headset with Your Phone for the First Time
1 Turn on your phone's Bluetooth feature.
For most phones, select Settings/Tools >
Connections > Bluetooth > On. See your
phone's user guide for more information.
2 Turn the headset on.
Press and hold the power button until the
indicator light flashes red/blue. The headset
is now in pairing mode.
If you don't see the red/blue flash, press and
hold the power button to turn your headset
off, and then press and hold the power
button again until you see the red/blue flash.
Pairing Your Headset
3 Use the commands on your phone to
locate your headset.
Devices > Bluetooth > PROPlantronics.
See your phone's user guide for more
information.
4 If prompted for the Passkey (PIN code),
enter 0000.
Pairing is successful when the indicator on
your headset flashes blue. Your headset is
now connected and ready to use.
Apr 02, 2011 | Cell Phones
Can I use a plantroics explorer 210 with this nokia?
You headset should work with the phone. Try following these steps.
1 Turn on the Bluetooth feature on your phone. For most phones, select Settings/Tools > Connections > Bluetooth > On. See your phone's user guide for more information.
2 Turn the headset on. Turn on your headset by sliding the power switch forward. Wait until the indicator light ?ashes blue and red. If you don't see the red/blue ?ash,turn the headset off, wait, then turn it on again. Wait until you see the red/blue ?ash.
3 Use the commands on your phone to locate your headset. For most phones, select Settings/Tools > Connections > Bluetooth > Search > 2XXPlantronics. See your phone's user guide for more information.
4 When prompted for the passkey, enter 0000. Pairing is successful when the indicator on your headset ?ashes blue. Your headset is now connected and ready to use
Jan 14, 2011 | Nokia 6060 Cellular Phone
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
For passkey enter 0000. Headset
and ready to use.
for 2 seconds until the light flashes
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
Connecting motorola headset h350 to T-mobile motorola phone
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Nov 16, 2008 | Motorola Mobility H350 Wireless Headset
Motorola H700 Bluetooth connection problem
4.Select H700 once a connection is detected.
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
Can pair, can't connect
maybe its already connected to another device, try disconnecting from the other device, then connect it to the one you want to
Feb 22, 2008 | LG HBM-710 Wireless Headset
Radio Communications Logo
100 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
