Question about Canon EOS 400D / Rebel XTi Digital Camera
LCD Display I haven't used my canon for a while - I've just turned it on and though the LCD display works to show pictures I've taken and the settings screen - I can't see anything in it when I take a picture (it's just black) when I press the Disp button it just switches from a black screen to the settings screen - please tell me what I can do so that I can see the image in the LCD before I take the picure. Thanks for your help
    Novelist:
  • 155 Answers
As far as I am aware, the 400D doesn't have a live preview mode.
What you are describing is perfectly normal and is how 99% of digital SLR cameras behave.
Are you sure it used to do this?
Matt
Posted on Feb 29, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Similar problems as other readers. camera turns on but no real time image on LCD screen. LCD contiues to show settings i.e. full auto mode etc. But I can view pictures already taken. Thanks
The XTi and prior EOS models have not capability to see the live image to be shoot on the screen. Only the image after taken can see on the screen. Other images also using the view mode.
If you can't review the images, eve if the display is turned off, just after they are taken, maybe the "Review time" is set to "off". Go to settings, 3th tab, Review time and set the desired setting.
Aug 03, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon sd900 will only take pictures that don't require a flash
Press the "DISP" button. Button on the top right of the bigger circle control button.
You can turn off the display if you want to conserve battery and use the viewfinder. So you probably accidentally turned it off. You can use that button to turn on/off the LCD display or change between two brightness settings on the LCD.
Hope that fixes your problem.
Apr 19, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon Powershot SD 1100ES - display problems
My mother has this model camera. I believe there is a setting in the main menu that will allow an energy saving mode that sets the display time or no display. If not it's under warranty and your retailer should replace it if it is within 30 days of purcase date.
I hope this helps, goood luck!
Nov 20, 2008 | Canon PowerShot SD1100 IS Digital Camera
Canon PowerShot A510
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
The LCD is black when I am taking fotos....otherwise it is working fine
Usually you would press the Display button to turn the LCD on, on with options, or off. I leave it off when taking pictures to save on battery life, though it does display each picture for several seconds after it is taken.
Jan 26, 2008 | Canon PowerShot S50 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon EOS 400D / Rebel XTi Digital Camera Logo
339 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
