Sony vio doesn't boot up
I press the power button, and the battery and power indicators light up, but nothing else, i think i hear the hard drive run but nothing. i reseated the ram and hard drive, i un hooked cmos battery hopping to reset bios, nothing, the fan doesn't even turn on, it is like the thing is dead. i even took out the battery, held the power switch 1 minute and replaced the battery, nothing. could my mother board be bad? oh by the way, i was given this laptop by a friend, he told me i could have it, since it doesn't work.
  • pippaminni Mar 05, 2008
    SONY VAIO-PCG-532A: won't turn on. please help.
  • Anonymous Sep 09, 2008
    i turn on the power switch but only the power ligth and battery will indecate but no picture?
    Problem Solver:
  • 9 Answers
Its most probley the fan reinsert
singed greazy guy.
Posted on Feb 29, 2008
Most likly its you graphics card wich is probly intigrated so you would have to buy a hole new motherboard
Posted on Apr 28, 2009
Sony PCV RZ44G irresponsive
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Just because you see lights around the power button does not mean that the Power Supply is ok. I've seen many times when the Power Supply makes the light around the power button come on and makes the light on the motherboard come on, but it does not have enough power to make the Fan inside the power supply come on or anything else.
Apr 22, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
Compaq presario v6101uswont boot not even start up screen
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
My sony vaio won't turn on
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
Laptop turns off after a second
One second after your press the power button or one second after it gets the the windows desktop? When you press the power button do you hear the fan running, see any lights, hear the disk drive spinning, hear the cd rom drive click once and see the light for about 2 seconds on the cd rom drawer? If all the previous is seen or heard it means you are getting power and it's trying to boot. If you see or hear nothing at all it means your power cord is probably bad. On most laptops once you plug the power cord in you should see a light someone on the laptop, if not the cord is bad. Also on some AC Adapter Power Cords they will have an indicator light on the adapter that lets you know it's functioning. It really sounds like your power cord went bad and the last time you were able to operate you were operating off your battery which is completely drained since the cord could not recharge it. One last thing to try is remove the power cord and battery from the laptop. Press and hold the power button for 30 seconds, then plug on the power cord back it and press the power button. if it boots you can put the battery back in.
Mar 20, 2012 | Computers & Internet
Laptop not booting up, fan and disc drive are recieving powrer and all indication lights are working but the screen remains black.
You might need to reset your Hard Drive and RAM.. You can open the portion of your hard drive and RAM easily and then take it out and insert it again... and then try to boot up.. ya dont forget to take out battery before you take out other stuff.....
The other solution is take out your battery and then press your power button and keep holding it for atleast one minute.. it will reset your motherboard to default settings...
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
