Question about Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B While trying to start a load after closing the door, I got several short buzzing sounds followed by LO on the screen.  Washer won't do anything...
  • ammo6 Mar 02, 2008
    Thanks
    After reading some other comments, I took the door switch apart and sure enough it was jammed.  Cleaned it all up and put it back in and it now works fine.  However, I did order a new one.  I'm sure this one will be back sooner rather than later.  Next time I'll just replace it.
    President:
  • 1,294 Answers
Before you order or try to change the door lock, try some WD40 on it........................................
Posted on Mar 13, 2008
  • 96 Answers
Buzzing sound is probably door trying to lock. May just need a new door lock.
Posted on Feb 29, 2008
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door lock failure
It sounds like your door lock unit has a bad wax motor. There are 2 wax motors on the unit. 1 which actually locks the door and 1 that presses down on a check switch to tell the computer board that the door is locked. The wax motor that is bad is the one that presses down on the check switch. It is not a part that can be replaced on its own and you will need to change the entire door lock unit
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
545 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
