Question about Brother IntelliFAX 2900 Plain Paper Laser Fax
Intellifax 2900 I have a black line on all incoming faxes. How do I clean this fax machine?
  • cpick Feb 29, 2008
    Thank you for the help, that fixedx the problem!
    Thank You for your help!
    Problem Solver:
  • 17 Answers
One of the most common causes of black lines on the 2800/2900's is the drum charge wire being contaminated. Remove the drum/toner unit from the machine, and look for a bluish/purple "slider thingy" on the unit. This can be slid back and forth from side to side of the print cartridge (on the 2800's it's on the underside of the unit... I'm not sure where it is on the 2900), and will clean the charge wire that causes a lot of black lines on the prints. Slide it back and forth 4 or 5 or 7 times or so, and then try printing something after your done. See if that helps.
Posted on Feb 29, 2008
  • James Mastrine
    James Mastrine Feb 29, 2008
    Glad to be of service. I would mention that if the lines return often that causes a need to continually do the cleaning thing, or it gets to the point that it quits being effective, you may just need to replace the drum unit even if the machine isn't calling for one.
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Outgoing faxes are black.
just copy a paper if copy is black ur scanner is dirty or dead .first clean scanner with tissue other wise change it.if copy is ok result not black that is due to telephone line.by mian jee
Dec 15, 2008 | Brother IntelliFAX 5750e Laser Fax
2 inch black lines on left side of outgoing and incoming faxes and copies as well
Sometimes the drum cleaning blade craps out. Remove cartridge and inspect the drum, it should be clean.
Sep 12, 2008 | Brother IntelliFAX 4100 Laser Fax
2" BLACK LINE
1- itis on the Scanning unit open and look for a thin strip of glass, clean
2-the scanning unit is bad
Assuming it's only on Outgoing Fxs and not incoming as well ( that would indicate the drum)
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 2900 Plain Paper Laser Fax Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
