Question about Sony Playstation 3 (PS3) Console
Playstation3 wont work after a couple of minutes
My little brother droppep my ps3 once and ever since then 5 mins after turning on it starts freezing, shuts down or screen turns multi-color and then it wont work no more until it cools down but when i turn it on again it does it again. what it could be? i got my ps3 as a gift and i dont have the receipt, how can i get it fix?
    Guru:
  • 147 Answers
I suggest leaving it alone until you contact Sony, as you may make the problem worse.
You should have a warranty on your PS3, even if it was a gift. Contact Sony as soon as possible and get an exchange.
Web: http://esupport.sony.com/
Please let me know if this helps. Good luck!
Posted on Feb 29, 2008
My playstation3 freezes and when it restart my controlers wont work what can i do?
on the back of your controller there is a reset button have to use a pin to get in and reset it as far as the ps3 freezing its probley the fan going bad and causing the ps3 to overheat, does it just freeze up or shut down.
Jan 17, 2014 | Sony Playstation 3 (PS3) Console
Hi my playstation keeps freezing and everytime i follow the instructions on the playstation it freezes again. it now wont start correctly. Could you help me please ?
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down. If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on. Check if there's any loose cables. If there is, put them back in.
If the problem still persist, try the below steps,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 09, 2010 | Sony Playstation 3 (PS3) Console
My playstation just freezes on start up screen and
hello,
"When the PS3 system freezes and wont play, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
May 30, 2010 | Sony Playstation 3 (PS3) Console
I was playing oblivion the the game froze for a bit
try this. works for slimline PS2.
1) turn off PS3
2) unplug PS3 and wait a couple minutes before plugging back in.
3) turn on PS3
hope this helps :D
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Playstation3
Becoz ur hard disc got corrupted ! But don't worry, U need swith on the PS3 & touch hold both the "Eject" & "Power/Reset" button for 20 secs or until a triple beep sound. It will restart the PS3 with a Message " Press X Button to restore the corrupted data ".. Enjoy.. !! =D
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 freezes but sound still works
when it happens, give it some time, like 5-10 min. the ps3 is most likely accessing the hard drive, and if it is, shutting down in the middle of it could currupt your hdd. if it doesnt work, even after 10 min, call sony tech support, but if it works fine afterwords, i dont see why it would be neccessary. unless it gets worse, i think you should just turn it on, turn it off after a few min, then back on, and then play.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 can,t pickup ip address
If you have your internet to your computer and the PS3 you need a router to provide an IP for both. Otherwise your ISP will only provide an IP for what ever was hooked up first most of the time. If this is the case try only the PS3 and do the auto setup. Linksys is a simple router with great support. If there is already a router hooked up please clarify.
Mar 21, 2009 | A.L.S. Industries Messenger Bag for...
My playstation3 keeps freezing and wont let me play some of my g
It is freezing because your playstation is to close to the tv and its getting to hot...it is due to overheating you are having this problem ... so try moving it to another spot....you must take care to keep it properly vented.......
The system is prone to overheating, particularly if you happened to have bought older stock.
One way to deal with this is to stand it vertical, and put a small desk fan behind it.Turn on the fan when you turn on the game. I know it's an annoyance but it is a very simple and effective way to work around the problem.
DO NOT use an intercooler fan or any cooling device that gets power from the playstation. It just makes it worse.
when thermal compound fails it gets overheated so you need to look into this too ...replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your playstation.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 keeps freezing?
The only thing I can recommend doing is backing up your info and then trying to get to the restore option under the ps3 before the green squares pop up, if you are not able then contact Sony before your lose your warranty.
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
