Question about Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case
Front USB, Where?
Where can I Purchase a front USB for this case?
  • 1 more comment
  • Michael Szwast
    Michael Szwast Feb 29, 2008
    That is where I bought the case, I can't find it anywhere on that site.
  • Michael Szwast
    Michael Szwast Mar 07, 2008
    I did not rate you inappropriat, I rated you Thanks for trying.
  • Michael Szwast
    Michael Szwast Sep 26, 2011
    Thank You!
    Problem Solver:
  • 9 Answers
I knew a online market you can buy the front USB with high quality products with competitive price on TOPONS.Pleasure share it with you.http://www.topons.com
Posted on Sep 26, 2011
    Problem Solver:
  • 9 Answers
    Guru:
  • 147 Answers
Threedz,
I highly recommend TigerDirect for all your computer needs.
Please let me know if this helps. Good luck!
Posted on Feb 29, 2008
  • Alexander Kogl Mar 04, 2008
    How was I supposed to know that? I gave you a solution based on what little information you provided, and you rate me inappropriate?!
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
My usb in front of the cpu have some problem
Most likely either the USB socket is defective internally, or it has broken off of the circuit board that it is soldered to internally. This usually happens from excessive use. The ports at the rear are plugged in typically once for a long period of time, but front ports get a lot of wear and tear. A repair or replacement is NOT recommended, unless you have experience working with/on electronic circuits.
A quick remedy would be to purchase a USB Extender cable. It has a Type A Male on one end and a Type A Female on the other end. The male would plug into a USB port on the rear of your computer and the female end would be available at the front. If it fails, just change out the extender. Or you could purchase a USB 4-port Expander hub and do the same thing.
Hope this helps.
Apr 30, 2014 | Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Mike
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Feb 08, 2010 | MSI K8MM-V Motherboard
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
USB56 Front USB hook-up to case
there is no chance to join differport to join in computer asmbaling. we should look port and size and conneting corner shape. we can asambling any port reading in bords smallptints and casing wire there is aprint in casing wire /reset/ p.led/hddled/ usb u can get front usb print in mother bord,
Oct 30, 2009 | ASUS P4S8X-X Motherboard
How do I attach the front USB, speaker and mic of the case to MB?
Follow that arrows on the pictures. Plug the USB Front Panel Cable.
Aug 06, 2009 | Intel Motherboard
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Flash Disk goes bad
Did you assemble the board yourself into the case? check to make sure your front panel USB connections are installed onto your motherboard in the correct order. Refer to your Motherboard Manual.If they are not, they can fry your usb devices rendering them inoperable on your pc or others. I have seen this before because of improper installation of front pannel USB connections. Good Luck
Apr 09, 2007 | Intel D915GUX Motherboard
Power Up 5511 (TC3J-4032 P) ATX Mid-Tower Case Logo
149 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
