Question about Carrier 36KCARMS Air Conditioner
Non-cooling Our 38AKS016/40RM016 split system is cooling a 24' X 60' room which has 4 open doorways to three other areas (cooled by different units). The room has ~30 PC's and 2 printers which are on continually. Sometimes when the outside temperature is below 30F, the system gets in a mode where the air mover runs, but the compressor does not. The room will equilibriate about 8 degrees above the temperature set point (71F) and the compressor will not come on until it warms up outside (or the system is recycled). Any ideas?
  • 236 Answers
- Calibrate your electronic thermostat if it is accurate. If not then replacement is needed.
- Check the location of your electronic thermostat, it may be installed in the room where its too cold.
Posted on Mar 01, 2008
  • Felizardo Erilla
    Felizardo Erilla Mar 03, 2008
    If your electronic thermostat is located in the room of indoor unit then the actual temperature of the room where your air out supply cannot be sense by your electronic thermostat. The sensor of your electronic thermostat is inside the electronic thermostat itself. So you need to install that in the room that you are cooling.
    To check if the unit have adequate refrigerant charge, check the suction pipe of your outdoor (the big pipe) if sweating or if you have the thermometer check the temp. of the pipe it should be from 50 to 60 deg. F. If it is higher than this or if the suction is dry you need to add refrigerant.
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
Not cooling anywhere near what it claims.
Try to turn OFF the Music Mode Only.
Turning on Music Only Mode will disable voice and data calls..
Regards
Sep 07, 2008 | Soleus LX-140 Portable Air Conditioner
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
Related to cooling
Sounds like you have poor insulation in that room or the unit is undersized for the room it is cooling. It should not get hot quickly is there is good insulation and is big enough to do the job. Since you do not mention the age of your home/room or the size of the room, I can't be more specific. The number of turns may or may not be an issue. Depends of which of the lines are taking all the turns. Are the lines insulated? If they are overly long this could take longer to cool down but not much else if the system in full of Freon. If you do not feel cold air coming out of the unit at all and the compressor is running then check the air filter. If it is the littlest bit dirty and the unit is undersized for the room then any restriction would make it even more ineffective.
Apr 20, 2014 | LG LSC121PMA Split System Air Conditioner
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Airflow throughout House
The system you have installed what is the kw cooling capacity? do you only have one evaporator installed?
Jun 09, 2009 | Fujitsu 18RC Air Conditioner
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Jan 02, 2009 | Vinotheque Whisperkool 3000 Wine Cooling...
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
141 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
