Ricoh/gestetner How do you reset SC550 code in Ricoh/Gestetner copier model gestetner 6603? thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hola si lo que te esta pidiendo la maquina es que cambies el cilindro y no lo as cambiado tampoco queres cambiarlo tenes que resetearla de la siguiente manera abris la cubierta delantera sobre la derecha por donde va el cil hay una ranura que tenes que poner un destornillador o algo similar prender la maquina y listo se te resetea la maquina creo que es eso probalo y contame cualquier cosa o duda
Posted on Mar 07, 2008
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Where I can download drivers from the machine DSM635sp GESTETNER Thank You Jorge
Hello!
Gestetner is made by Ricoh. They only change the name. The cross reference for your model is Aficio 2045e.
You can download from the www.ricoh-support.com the driver of Aficio 2045e and your done.
Hope this helps you.
See you!
Jun 23, 2011 | Gestetner DSm635sp Digital Imaging System
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 06, 2011 | Gestetner A045 Wide Format Copier
Do You have anyone in the ocala florida area that services gestetner cpoy machines?
Look for a copier dealer or service center that is listed as repairing Ricoh, Savin or Gestetner. They are all the same machines. In other words your Gestetner copier is made by Ricoh and Ricoh Dealers are far more common and easy to find than Gestetner. If you need to know the exact model then just reply with your Gestetner Model number and I can tell you what the Ricoh equivalent number is.
Hope this helps.
WheatlandServices
Dec 08, 2010 | Gestetner Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
I JUST BOUGHT A NEW WINDOWS 7 AND i CAN'T FIND THE GESTETNER DRIVER 4532 TO DOWNLOAN. THANKS SCOOTER
Scooter, the Gestetner 4532 is the same machie as the Ricoh 2045. Here is a link to Ricoh usa web site for drivers. Are you running Windows 7 32 bit or 64 bit. Both drivers are available on this site.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x2035_2045/x2035_2045en.htm
Oct 29, 2009 | Gestetner Copier
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
I need to know how to set up a fax number for a sales person on the DSC445, and we can not find the man manuel thanks Anna May
RICOH makes all of machines for gestetner...actually owns them, so it converts to a "Ricoh Aficio 3245C" and user manual can be downloaded here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/c35_45/c35_45en.htm
Jan 27, 2009 | Gestetner Copier
Gestetner
Gestetner is made by Ricoh so go to Ricoh USA downloads for operator manuals.
May 12, 2008 | Gestetner Copier
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
