HP M1005 problem
Will not work and displays "no print cartridge"
There is a cartridge in place and the door is shut.
  • Martin Lamb Mar 05, 2008
    Thank you. I immediately solved this problem when I knew the error message also referred to a paper jam . I was able to find a very small piece of paper in the mechanism which was not previously obvious
The solution is here!!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00159306&jumpid=reg_R1002_USEN
the cartridge sensor is attached to the paper tray sensor, so when a paper jam occurs, it triggers a cartridge error.
HP updated the firmware for the 3000 multifunction series (same design) so it nows read "paper jam/cartridge error" instead of 2no cartridge". They will get to m1005 firmware update eventually.
Greetings from Argentina!!
Kuru
Posted on Mar 05, 2008
Same problem, no solution yet... this happened to me on the same date!! could it be a bug in firmware!
No catridge show on display hp laserjet 1005mfp
I suggest You Go to Official Hp Printer Page For You HP Printer Problem On Below HP forum URL Link: No print cartridge Message Displays on the Product In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Feb 26, 2014 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Trying to print on HP Laser Jet M1005. Printer shows no print cartridge although the print cartridge is in the machine?
Have you tried to turn off the printer and reinstall the cartridge? Try a few more time and to see if this works. Or, if your cartridge is a low quality generic one, the printer might just can't detect the cartridge. Just get an original hp q2612a toner will help solve the problem.
Aug 20, 2010 | HP Office Equipment & Supplies
Hp M1005 Laser printer showing no print cartridge while I've replaced a new cartridge.
hi
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
May 20, 2010 | HP LaserJet M1005 Printer
How do i refill my HP M1005 MFP Laser Printer toner cartridge?
You should not refill the cartridge...they are a one time use only in any HP laser printer. To use a refilled or refurbished cartridge either voids your warranty, and if you have a printing defect as the result of not using HP-branded toner or an refurbished cartridge HP will not be able to do anything for you...I used to work for one of their call centers doing printer support, and this was a common theme.
There are many places that may advertise that they refill the cartridges with HP-approved toner, but that is far from true. In order to keep your printer functioning properly, even though it may cost more, it is in your best interest to only use new HP cartridges in your unit.
Jul 26, 2009 | HP LaserJet 8500 Color Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
756 people viewed this question
jasbo
jasbo
