Question about Technics SL-1200MK2 Turntable
Power failure The power has gone in one of my decks dont know how this happened,its not the plug as i have changed and tested? I havent opened it up yet as im worried of what damage i might cause,any suggestions
  • 515 Answers
First check to see if your turntable has fuses installed on the main PC board, which is located underneath the turntable platter. They should be easily visible once you remove the black protective cover underneath your turntable platter. Check them out first to see if they are blown, if so, replace with equal rating fuses. If you don't see any fuses, or the fuses look fine, then your power transformer has gone out - this is the grey metal box looking thing next to your PC board. This would need to be replaced. Parts for this model can be purchased HERE - just pick your turntable, and that's it!
- DJ PRO LAB
Posted on Mar 01, 2008
I have swift vxi 2010 model . its steering has become heavy and speedometer gone dead. EPS light is on wat can be the problem
check all fuse in both fuse boxes.
power sensor?
electronic power steering failure.
you can:
1: get it fixed. (any ASE shop would be happy to help.)
2: read the FSM and learn the tests to find the cause.
3: and scan the PCM to see what EPS failures are happening,
and post those.
or look them up in the FSM to see the tests.
Mar 11, 2014 | Suzuki Swift Cars & Trucks
My w395 sony ericsson phone will not charge i havent used it for a year, how can i fix it?
change the battery.your battery has gone down because of not using it. and even you cannot switch it on by plugging the charger.
Mar 31, 2012 | Sony Ericsson Ericsson Spiro Cell Phone
Teac X3 does not fast forward
There are larger Alp switches on the transport switch assembly that are known for burning out and becoming open. Your switches are just about there. This does not doom the machine though as I have designed and tested a modification that put relays in the unit that should have been designed into it from the start. I know this mod works as I have tested it, in addition I am a past Teac Technician and an Electrical Engineer. In my years at Teac in Arlington Heights I changed about 120 of those switch assemblies but you can not get them anymore. It is better to install socket relays and just rely on those. If they ever go bad pull out and plug in a new relay at about $3.00 a part. These are the same relays that have been used in the A2300S model that have lasted 35 years without failures. I cab send you the schematic and part list if you contact me at Skywave Tape Deck Repair. I am still repairing decks 7 days a week.
Feb 06, 2012 | Teac Audio Players & Recorders
System crashed and will not restart
BEFORE ATTEMPTING THIS HOPEFULLY YOU HAVE DONE A BACK UP OF DATA,DONT TRY THIS IF YOU HAVENT OR YOULL LOSE ALL DATA ON COMPUTER.
STEP 1 ; HOLD DOWN THE NUMBER 0 ON KEY BOARD AND TURN ON LAPTOP THIS WILL START YOUR MAIN TOSH PAGE QUICKLY TAKE FINGER OFF KEY (0) AND IT WILL BRING YOU TO AN OPEN FROM BOX STATE IT WILL RELOAD COMPUTER FROM START IT TAKES A FEW HOURS SO PLUG IN POWER SUPPLY.
PLEASE DONT DO THIS IF HAVENT SAVED DATA.
I HAVE A TOSH AND WHEN YOU GET SICK OF P[ROBLEMS HAPPENING LIKE THIS TRY IT AS THERE IS NO HARM IN TRYING
Feb 20, 2011 | Toshiba Satellite Pro P300 Notebook
Hi I am a solo female vocalist and I have a pair of jbl two way eon 10s speakers which are about 10 years old now. But have looked after theem and they have served me well. But a few weeks ago i heard all...
It sounds like the Power Amplifier shot a big jolt of DC Voltage to the Speakers and opened the Woofers. If this was the case the speakers would read open and not the 8 ohms they should.
If this happened than your horns will be the only thing working and this would give you a tin bucket voice. Have your Engineer check your Amplifier................. Larry
Oct 09, 2010 | JBL EON-1500 Main / Stereo Speaker
Is it possible to change a fuse
the 1.0 A is the amps .
bose are very secretif when it comes to the the Head deck .
if you are keen on opening the head deck and try to look for a fuse , go ahead but i would suggest to doe the following , place a set of hear phone in the jack output and turn the music on .
if it does work , you may have blowned the main speaker output .
if it does not work at all , you may have fuses may have gone but check inside the system as next to the speakers output you may have a fuse in line hidden .
Please make sure all power is diconnected prior to opening the device .
best of lack and let me know how you go
Sep 29, 2009 | Audio Players & Recorders
PICTURE IS COMING IN PURPLE SHADE
CCD has gone bad , it is the sign of CCD failure first pics gets purple shades and overexposed white seems like pink purple and then all off dont spend time and money in diagnosing th fault i am 100 % sure abt it, i dont think it is worth to get it replaced u can get a new one around the cost replacement , fuji and nikon are good in results
i know i havent fixed ur problem but no body can in this situtation
pls rate me genrously bcoz i helped u in diagnosing ur problem without wasting time
Mar 06, 2009 | Kodak Easyshare C813 Digital Camera
Power failure
Hi Darren,
Out of curiosity, how did you find out it was this part at fault?
My deck has just had the same thing happen to it :(. Unfortunately turntables are not popular in Cyprus, so it looks like I have to diy it.
Sep 27, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
297 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
