Question about RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
Does anyone know where I can locate the convergence IC's in a RCA R52WM24 52 in. HDTV. I don't see anything with STKxxx on it. If fuse FL231 keeps blowing, would the convergence IC's be the next place to start?
  • 1 more comment
  • Hans007 Mar 25, 2008
    Willtab,
    I just would like to thank you for your input in this matter. You were right on with your analysis. I made the fix over two weeks ago and the fuse has NOT blown this time. It WAS the solder connection on the flyback. The solder points were very sloppy and the solder was gobbed on. I actually just cleaned up the existing solder that was already layed down. Ok, so for anyone else with this problem:
    Find the flyback. Its the big black transformer to the left (bottom lefthand corner of board) of fuse FL231. Resolder the points on that flyback and then put fuse FL231 back in and your problem should be taken care of.
  • Ryan4584 Feb 18, 2009
    R52WM24/ chassis itc222. My tv is having the convergence malfunction with no convergence in the menu and severely bowed image with color distortion. It has been going on a while, and now is to the point where the tv will occasionally shut itself on and off with a straight red/green/blue line going across the middle of the screen if it comes on. I looked in the back, and i can't find any of the circuitry people have listed. I don't know if i'm looking in the wrong spots or not.
  • Anonymous Mar 14, 2009
    I have the same problem with my tv, no convergence in the menu distorted picture, I located fuse FL231 and its ok, now what?
    Genius:
  • 1,030 Answers
The rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Posted on Feb 29, 2008
How to change chips rca
I think youre refereing to convergence Issues?? If so your model doesnt have IC chips like most other brands. If your model has a convergence issue its fairy easy to fix. let me know if the issue is convergence or not and I will assist you with the issue.
Oct 24, 2011 | RCA R61WH76 61" HDTV
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Nov 01, 2010 | RCA HD52W59 HDTV Projection Television
I can not get colors to converge the option does not come up in the menu
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Can not find convergence ic's in our hitachi big screen tv
Hitachi uses STK392-110s upgrade to 150s also replace RK42-2.2ohms,RK46 1.5ohms, RK50 2.2ohms RK54 1.5ohms RK58 3.3ohms RK62 1.8ohms,CK RK60 also.
Aug 20, 2009 | RCA R52WM24 52" HDTV Projection Television
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
Aug 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Jun 04, 2009 | RCA R52WM24 52" HDTV Projection Television
R52wh74 Convergence
If the convergence option is not on the menu anylonger. thats another issue all together. That is usually a fusible link and capacitor on the deflection board that will cause that to happen. The convergence ICs will also need replacing as the link and capacitor will most certainly take out the convergence ICs as well. You will need a service manual on this issue. Let me know and I will post a link where you can get one along with some free support to help you with it.
Mar 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergance problem
vin, board replacement is BIG bucks, IF it`s available, convergence IC`s are located on a large silver colored aluminum heat-sink, on the board they will be marked IK04 & IK05, they are probably STK 392-110`s or STK 392-150`s, those 2 will have to be replaced, check all of the low Ohm resistors lined up in front of the IC`s for dis-coloration, replace any that look slightly burnt with the EXACT rating or the new IC`s will fry, if you have questions e-mail me back, If you are not proficient at soldering & un-soldering and if you don`t have a good voltmeter, don`t attempt this repair yourself, BMW Rider
Dec 27, 2007 | Hitachi 51F500 51" Rear Projection...
Philips 60pp9202 sound but no picture
Sorry no pic, but if you look from back of set on deflection board(board with HV transfromer)big part with about 4 wires coming out going to your picture tubes. Looking close to leftside of board the last IC with heatsink shield standing up has a small 7 pin ic if looking on it you should see TDA8177 or something to that affect. This is the verticle IC. Since you have found the IC's (convergence) then the only thing left is to look for open fuses like 1300, 2004, 1900 etc and see if open. Concerning cost if you buy from www.bluestaronline.com these part are inexpensive so it wouldn't hurt to buy all. Rule of thumb, if set has color problem then Convergence IC, if no problem just went out one day while playing fine then Vertical, then the alternative if no sound the audio area, which is not common for this set. Hope this helps!
Sep 03, 2007 | Philips 60PP9202 60" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
2,094 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
