Question about Intel D875PBZ Motherboard
Won't power up CPU fan
The computer was moved a few blocks and won't power up now. The 5 volt led comes on but no fans turn on with power switch (including the cpu fan). Checked the switch, ok. Tried a new (good) supply, no difference. Tried the cpu in another motherboard, ok. Does anyone know where I can get a schematic for the MB? It appears that somewhere I have lost the "power ok" signal going back to the supply.
  • Anonymous Dec 13, 2008
    Exactly the same problem...
    Guru:
  • 147 Answers
Pine,
It sounds like you have a short somewhere in the motherboard and should have it replaced. The website for this product can be found here.
Also, I found a technical guide for you which may help.
Download
Please let me know if this helps. Good luck!
Posted on Feb 29, 2008
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
Have an asrock 939sata2 I hit the power to turn on the led lights up along with the floppy drive light all the fans come on but that's it nothing else any solution?All the fan motors come on but t
Power Supply with a weak voltage power rail.
[There are 3 voltage power rails. 3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage ]
Enough power to light LED's, and spin fans, but not enough power to turn the Processor on.
1) If ALL of the LED lights were on at once they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
Suggest you check the three main voltages with a multimeter.
Since the Soft Power On circuit uses 5 Volts, I have a feeling the 5 Volt power rail may be the bad one.
An economical multimeter can be purchased for as little as $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Need guidance in using it just post in a Comment.
Or you can borrow a KNOWN to be good, Compatible power supply, and use it for a test unit.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Sony ASROCK 939Dual-SATA2 / 939DUAL SATA2...
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
My Sony Vaio PCG-61611L won't power on, the battery is fully charged and AC adapter is working (green light goes on). Please help!
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 15, 2012 | Sony Computers & Internet
Gateway GM 5072 won't turn on, it just flicker.
One of two things a clogged up CPU fan and block may be the contributor over heated and possibly fried the board. The other issue may be a bad power supply unit, replace the unit and reboot. John
Apr 14, 2012 | Gateway GM5072 (6576) PC Desktop
ECS RC410L/800-M (V2.0) motherboard won't boot up. lites the fans and system lights, but no go. replaced video, CPU with 800 fsb from 533 existing and cleared cmos, still nothing. 533 processor creates...
A bad Power Supply with a weak voltage rail, will produce the symptoms you've just described.
1) IF all of the LED lights were on at once, they would use less than 1 Watt of power.
3) A typical Processor can use from 51 to 125 Watts.
You press the Power On button. The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
BIOS detects what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S)
Have you tested the main voltages of the Power Supply?
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail
(12 volt rail must be 11 volts or more. Less = new Power Supply)
Post back in a Comment.
Regards,
joecoolvette
Oct 28, 2011 | EliteGroup RC410L/800-M (V2.0)...
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
Installed Crosshair MB in new case. Motherboard LED lights come on but CPU and fan do not light up or turn on. Tried dif power supplies and cases, no luck.
Make sure that the motherboard LED switch on the back panel is set to off and if want to turn it on go into bios and set it. If it is active thru switch and not thru motherboard bios it will not allow you to turn on PC cause it is in maintenance mode.
Oct 26, 2009 | ASUS CROSSHAIR Motherboard
M2N MB LED is on, fan comes on for 2 seconds only
It's a bad power supply. Couldn't be a bad Power On switch, because it turns on for 2 seconds.
You have to have Ram to get the computer to function, besides the processor. All you will see is the BIOS Setup screen.
Been using the same power supply?
The power supply has bad Electrolytic Capacitors in it. These bad 'Caps' in turn make a weak voltage rail. You have three main voltage rails inside a computer power supply.
The 3.3 volt rail, the 5 volt rail, and the 12 volt rail.
With a weak voltage rail, the processor won't have enough power to run.
ALL the lights, (Lamps), use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
Processors use 55 watts to 125 Watts. Depends on the processor.
Jul 25, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Intel D875PBZ Motherboard Logo
154 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
