Question about Vacuums
Belt for handimate jr - Vacuums
  • 2 more comments
  • johnschmitt Mar 01, 2008
    Thank you, Sears said they don't sell the belt, a $2 itme, you have to replace the whole unit, $19. The belt should be a consumable item, it is very easy to access and replace. I have the part number of the belt, HTD2M-160, but haven't been able to find out who the manufacturer is.
    The vacuum is a Kenmore, 72126823600 and the Handimate jr is 5249FI1432D.
    Thanks - John
  • johnschmitt Mar 02, 2008
    Thank you, Eureka sounds like a possible solution.
  • marbar2 Sep 08, 2008
    I'm having the same problem - the tiny belt stretches and Sears wants to charge $25 for a whole new Handi-mate jr. Is there a corresponding Eureka part number?
    Thanks,
    Mary Jo
  • Anonymous Dec 02, 2008
    Same problem. I spoke to a nice lady at 1 877-531-7321, the number posted on the vacuum. She works for Panasonic, the actual manufacturer of the unit. She was not able to tell me where to locate a replacement belt but said she would "ship one out" to me. Hopefully, she will be able to.
    Rick
    President:
  • 1,673 Answers
Need to know brand and model number, but if this is a Sears, then go to sears.com, click on the parts link, put in your complete model number, then you can get the belt thru that web site.
Posted on Feb 29, 2008
  • Lauren Junge
    Lauren Junge Mar 01, 2008
    On some items they will do this, it is a replaceable item, not deemed repairable. You could take the old belt and go around to different repair shops to see if you can find one the right size. Eureka has alot of small belts, cogged and flat, you may find one at a place that has a good selection of Eureka belts. The number on the belt may be just a manufacture or vendor number and not a good part number.
Bissell Clear View Plus 12-Amp Vacuum
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjf
Jul 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Power-mate jr belt appears to be loose, as will not turn brush. Can it be replaced? Looked online and could not find one.
Greetings,
You're in luck! I found the belt for you Powermate Jr. below; If you need help installing this belt, please start a new repair here on Fixya, and I'll be more then happy to walk you through the repair of this. If this helped, please be sure to click the thumbs up icon to rate it as helpful. This helps the Fixya community keep answering questions. Thank you,
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=8192011&productGroupId=0020&supplierId=116&brandId=x&documentId=P0601002&keySuffixId=NA&modelNumber=x&keyId=000010&pageId=00002&productTypeId=x&searchModelNumber=11625513506&subCompDesc=Attachments&brandDesc=KENMORE&modelDesc=CANISTER-VAC&blt=11
Mar 21, 2010 | Kenmore 25812 / 25813 Progressive Bagged...
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Dec 13, 2009 | Kenmore 31913 Progressive Direct Drive...
I need a replacement hose assembly for the hoover steamvac jr. any suggestions where i might find the part?
Only through a Hoover warranty/ service center if still available. If not save your hose ends and find a different hose with adaptable ends
Nov 25, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Handimate doesnt spin!
try ajusting the height if the beater bar also check the belt and motor
somtimes **** gets stuck in the end bearings and add resistance to the beater bar slowing it down remove beater bar abd check assemby for thread and **** build up
Aug 03, 2009 | Kenmore Progressive Bagless Upright with...
My handi-mate Jr. is not spinning anymore. What should I do to fix it?
Assuming you don't have a broken belt, you can pretty much completely disassemble the Handimate and clean it out, which should fix "it won't spin any more." Part of the cleaning procedure is pretty obvious - there are tabs on the side that hold the top onto the bottom. Just lift the side flaps on the top section that surround the tabs to release the top section. Pay attention to how the thing is put together so you can reassemble it - there aren't many parts - it's not rocket science. Now the part that's not obvious: it's not too hard to pull the axle out of the cylinder to which the brushes are attached. Gunk, hair and fibers can get caught under the white end caps and around the axle.
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Handi-mate jr. manual
I scanned my manual, but I can't fund any way to attach it here. I can send it to you if you provide your email address.
Mar 19, 2009 | Vacuums
Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Oct 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Vacuums Logo
563 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
