Question about P.I. Engineering PI Engineering X-Keys Stick USB Keyboard
Card PS2/USB-C VER 1.3 OF PI ENG.
We are user of seversal keyboard (20 nr) with little card Card PS2/USB-C VER 1.3, but there are not spare part for it.
In a card there is a chip CY7C63413-PVC, programed and loocked to copy.
Where can I download xxxx?.bin file for record a new chip?
Thank for help me
  • CHILOTE Feb 29, 2008
    The keyboard include trackball, funtion key and other
I purchased a used HP keyboard mod 5187-7583 but my computer does not recognize it. I'm using Windows 10-64. Do I need to download drivers for this keyboard?
It could be the "adapter", read this The pros and cons of PS 2 to USB adapters and converters
If you really, really like this keyboard you could always install one of these 2 Port USB 2 0 2 Port PS 2 Combo to PCI Adapter Converter Card NEC Chipset
Personally, I don't see the sense this is a old keyboard and HP didn't even release Windows 7 drivers for it, forget about Windows 10. This means that none of the special function keys or media control will work.
Feb 27, 2017 | HP Computers & Internet
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
Need to use a Dell L100 keyboard on my old Win 98 SE computer (custom built). No USB on computer so tried an adaptor. Doesn't work at all. Do I need to download a driver? Where can I find this to...
Those USB to PS2 adaptors are hit and miss. They shouldn't need a driver. What you could do is buy a USB PCI controller, which will allow you to connect USB devices to your legacy system. Best buy sells one for $20 and it works for 98 SE - Windows 7.
http://www.bestbuy.com/site/Dynex%26%23153%3B+-+2-Port+USB+2.0+PCI+Card/7833785.p?id=1142298626004&skuId=7833785&st=usb%20pci&cp=1&lp=2
Regards, Chris
May 18, 2011 | Dell 0Y3740 Keyboard
My computer seems to boot up fine but my monitor says no signal and my keyboard doesnt work
You can try tighten up the cable behind the monitor or disconnect the cables and reconnect. You can try another monitor to see whether the mother board and the cable works. Some settings in BIOS may be changed to use on-board video card (the one embeded on the mother board, which is connected on the ports out of the card slots) on your computer so make sure it is using the graphic card that is connected to the monitor. For keyboard, if may be mechanic issue on port or keys or cables if you will not see anything wrong about the keyboard. You can try to use another USB port if it is an USB keyboard or use a USB/PS2 converter if the PS2 keyboard port is not working. If it is a PS2 keyboard, you can check whether the pins are bent and reconnect it. Sometimes that helps. If it is a wireless keyboard, then you will need to fix the monitor and then maybe fix the driver and stuff. You can remove all objects beneath the keys by putting it upside down and shake it or use a blower.
Jan 05, 2011 | Computers & Internet
My friend has an hp he bought - one or two years ago, everything works fine except the mouse and keyboard ports are all messed up from the cords being ripped out and put back in, is there any way to just...
Try the keyboard and mouse on anothe system. if it works fine the on board PS2 port is most likely bad. Buy a USB keyboard and mouse in plalace of the PS2 keybaord and mouse or change the motherbord. If the keyboard and mouse is bad replace with a good one.
Sep 28, 2010 | HP (D7580-60003) Motherboard
Replaced my power supply, now keyboard and monitor wont work.
Believe it or not, if you have a floppy drive in your computer, try unplugging it and disconnecting the data ribbon. Many times, damaged floppy drives can short out motherboard functions and even prevent computers from powering up. If that doesn't fix it, then get a usb keyboard and mouse set (wireless would be fine) or borrow some, and see if they work. If they do, then the power outage damaged the PS2 ports.
May 25, 2009 | E-Machines eMachines Monitor E15T4
BSOD at start of Windows XP Setup
try F8 to got to the startup menu, and choose last known good configuration, use a ps2 keyboard or an adaptor and nothing that needs the USB.SYS Driver to function, and you should be able to reinstall Windows, if last known good configuration doesn't work, i hope this helps, please give good rating
Apr 30, 2009 | Computers & Internet
9600gt card, mouse freezing in games
you can't get rid of the PS2 because thats where it looks for the mouse, being usb it's not listed in dxdiag, there should be a mouse menu from your mouse and keyboard driver, or in control panel to tweak the Dpi
Aug 22, 2008 | Computers & Internet
Doesnt wake up to keyboard
an OLD 3 gig hard drive ?????? for £20 why not get a more recent 40 gig hd..
Oct 28, 2006 | Foxconn EBOT Small Form Factor...
P.I. Engineering PI Engineering X-Keys Stick USB Keyboard Logo
54 people viewed this question
Top P.I. Engineering Computers & Internet Experts
David Payne
David Payne
Are you a P.I. Engineering Computer and Internet Expert? Answer questions, earn points and help others
