Question about Polycom Small ClassStation VSX 8000 (223022120001)
VSX 8000-Far end focus for multi-sites during different connections is out-of-focus. Tried to adjust using the "far-camera" capability but it did not work. Far-end tried to manually re-set their camera-did not work. About to re-boot the system, any other suggestions?
4 Suggested Answers
SOURCE:
SOURCE: Could not connect to our VSX 700 polycom over ASDL
for VC over IP, both end should have a dedicated bandwidth with PUBLIC IP.
this solves most of the problems that are faced in a vpn or shared network like situation!!!!
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: Polycom VSX 8000-- cant hear
If you cant hear anything then this is a firewall issue not the VSX8000. Call us for port openings. 415.637.9989 . If the unit works on a LAN but not outside your firewall this is what it is. If it does not work on a LAN then it is the VSX8000..
Posted on Apr 21, 2009
SOURCE: I hvae a Polycom HDX 8000 HD unit and i'm trying
Can you use a polycom vsx aptz-2p camera with an hdx 8000
Posted on Nov 19, 2010
3 way video conf
Your VSX 6000 does not support Multipoint. YOu will have to move up to the VSX 7000 or 8000. The VSX 7000 supports MP and the VSX 8000 supports 6 site mp if you have that option installed. DAVID
Dec 12, 2012 | Polycom VSX 6000 (220022222001) Video...
Distance photo can not capture but close ok
I wonder if your autofocus is having problems. It may never get a distance number and is just sitting there waiting for it to figure out how far things are.
There is no other real difference when taking close or far just the focus. If you take the camera and set it to manual focus to try and take some distance shots. If that works then that is the problem.
As far as fixing it that depends on the value of the camera. Unless it is one of the higher end cameras the cost of repairs will be more than a new replacement camera. If you have warrenty this is covered. So check out your warrenty, check out the repair cost estimate, and check out what a new camera will cost. If you don't want to spend the money then your only option will be to learn how to do a manual focus for distance shots. It isn't hard just take a little practice. Unlike close photo's distance ones are not that picky for focus.
May 05, 2010 | Cameras
Connects to far sites but there is no image, only a black screen. near site image is fine.
When i connect the other end successfully(all the blue balls color turned to green)but with only a sentence, says:"secure conference encryption 。。。"
Nov 06, 2009 | Polycom VSX 7000 Video Conference
The angle of the headrest is too far forward on 2010 ford focus
try cleaning battery connections and starter connections if this does not help check timeing may be out. check nfor possible over heating. berrydalewolf
Oct 26, 2009 | 2009 Ford Focus
Polycom VSX7000 video camera
Hi there:
This happened to my VSX camera and the fix was simple. I have a VSX 8000 so if your camera is different then mine you might not be able to follow this. This might not work for you but, try it. On the back of the camera you'll find a small little screw. Keep the system on and watch your cameras image. Start to loosen the screw. You'll only have to do it a little bit and the camera should start to focus again. Tighten the screw up (maybe not as tight as it was before) and test to see if it's auto focusing. Also....manually moving the camera around while it was on could have helped as well. Finally....I did not have to do this but if it is not working simply by loosening the screw...I would take it all the way out and remove the little cover or hatch that it holds. Poke around in there a little bit to see if the the focus motor unsticks itself. If you are still under warranty (I was not) don't do this...call the vendor who sold it to you.
Mine's working great now simply by loosening this little screw and tightening it back up.
Feb 04, 2009 | Polycom VSX 7000 Video Conference
VSX7000 series VC remote site cannot see the video of near end
hi
for video conferencing at such long durations over IP, it is a MUSSSST to have dedicated stable bandwidth at all the locations.if that fails, symptons like the one u experieced are possible.this will generally happen during working hours when bandwith usage by pc's is high!!!!!
Dec 15, 2008 | Polycom VSX 7000 Video Conference
Nov 22, 2008 | Polycom VSX 7000 Video Conference
Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
May 06, 2008 | Polycom VSX 7000 Video Conference
try increasing the volume using the remote. Also have you connected external speakers?
Let me know.
Apr 08, 2008 | Polycom Small ClassStation VSX 8000...
Polycom Small ClassStation VSX 8000 (223022120001) Logo
48 people viewed this question
Top Polycom Lands Phones Experts
pbxinc
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
