Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door will not open all the way
My garage door will only open about a quarter of the way then you have to shut it and try again. After about 5 trys it will open or if you are using the inside pad you have to quickly hit it twice to almost trick it into opening...can someone please help me please!!!! I thought it was a sensor problem but the left one is orange and the right one is green as it should be. any other suggestions?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
I would suggest un-hooking the garage door from the opener (usually just pull the cord hanging down), and then try to lift the door manually. If you find it hard to lift then the problem could be that you need to tighten the springs so the door lifts easier. The opener only wants to lift so much weight and if the springs are too loose it makes the door too heavy. The weight makes the opener think it hit something on the way up - so it goes back down.
Posted on Aug 03, 2010
  • 2,326 Answers
There seems to be a loose connection somewhere in the controller circuitry. I would suggest to visually inspect the solder connections on that controller board using a magnifier aid between 2X to 4X.
Good Luck.
Posted on Feb 29, 2008
Starts with the remote but shuts off when a door is opened
Garage Door Opener Troubleshooting step by step - YouTube
? 3:41
https://www.youtube.com/watch?v=b8w2w5ZAc1I
Feb 5, 2014 - Uploaded by Andrew Hill
How to Fix A Garage Door Opener - the opener shown is the Craftsman 1/2 HP ... First start with the obvious and easy to check problems. ... opener button on the wall will open the garage door but not your remote or keypad, ...
Auto Start Engine Shuts Off When open door -
The Top 10 Reasons Your Garage Door Won't Work
customoverheaddoors.net/reasons-your-garage-door-wont-work/
Jun 5, 2014 - To help you troubleshoot your garage door issues, here are the top 10 ...Garage Door Closes Part Way, Then Opens Again ... Automatic Garage Door Opener Runs for a Few Seconds then Turns Off but Door Doesn't Move
Jan 05, 2016 | Building Materials
Garage door will not stay down when closed
Sounds like the down limit is out of adjustment. Turn the Down limit switch opposite the direction of the arrow a quarter turn and try again. Repeat until the door stops before hitting the floor then fine tune to shut off at the floor.
Aug 14, 2011 | liftmaster Garage Door 1/2 Hp
Garage door goes up halfway and then stops
There are 2 amall holes on the back of the unit. One is for force and one is for travel. If this just happened then you need to turn the force screw one quarter turn to the right and then try it again. You should not have to adjust the travel one unless this is a new unit. If you have more problems after turning it too much then there is a problem in one of the door hinges or the chain. Thanks for using FixYa. Let me know if this helps.
Jan 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
I am having the same problem. My door will close if I hold the garage door button down in the garage, but if I try to close it with the remote it goes down a quarter of the way, the light flickers then...
You have a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. Sometimes very hard to see. Tweak them just a bit. The color of the sensors is normal.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
The light flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small printed circuit board just in front of the motor. I would really doubt it is a motor problem unless you have been operating the opener enough that the thermal overload protector has shut it down. It will start running again as soon as it's cooled off.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
88 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
