I only get 82 channels when I should have 99
Hello! I have a Jerrold CFT 2014/V5S8 CATV Converter and I only get 82 channels when its capacity is 99, how do I open the mising channels? Thanks
Are you sure that you only have 82 channels or does the receiver only go up as high as ch 82?
Posted on Mar 07, 2008
Do I need a converter box for a Hitachi 53uwx10ba TV?
Check to see what input the set is on--set in menu to catv or cable and connect with set on three if using a box---if not then auto program for channels.
If set on catv you should with the remote be able to direct enter a channel to see if tuner in set works or hook a dvd etc to a rear input to set to see if it works that way.
Nov 03, 2012 | Hitachi 53UDX10B 53" Rear Projection...
How to get tv to receive cable channels aove 99
model indicated will not go there unless a catv box is connected to it and used for channel selection.
May 19, 2012 | Sharp 13N-M100 13" TV
Can only pick up chanel from 2 thru 13,do i need a box converter all other tv get 98 stations
A converter box will allow you to get all the channels but if you are only getting 2-13 now go into the customer menu and I think you will find the set is in the AIR band and not the CATV band.
With the remote you should be able to move it into the CATV or cable mode and then if needed find and select auto program.
The fact you are only getting 2-13 means it is not in the CATV or cable mode.
If this helped you rate this solution as I do this here for Free.
SD TECH
Dec 07, 2009 | Pioneer SD-P6093K 62 in. Rear Projection...
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Unable to program channels above #36
ON THE CABLE SETTING ALL YOU GOING TO GET IS #36 this is an old tuner . in those days there where never going to be 36 channels ! the thing your getting hung up on is the marketing of the 110 ch tuner how that works take73 brodcast chanels add 37 cable chanels and you get 110 ITS ALL MARKETING
Mar 25, 2009 | Emerson Televison & Video
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Televison & Video
QUAM TUNER
Doubt it. We ran HD through our small CATV system using consumer grade modulators but could only get them on the AIR frequencies, as we had very limited bandwidth as we had to carry 64 analog channels plus digital HITS packages for our Motorola DSxxx series boxes. Try plugging the CATV feed into the ANT input and do an autoprogram, or tell the tv to look on the AIR frequencies when it asks if you have CATV or AIR. Worth a shot though.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No recption pass channel 12
judging by the year, this set should definitely be cable ready. check the front of the tv if it has a control panel for a switch that says catv/normal or something similar, if it does not have that switch, check the settings via the remote.
the channel a connector may require an adapter depending on the type of connector. i had an old tv that required an adapter in order to plug the cable coax into it, it resembled an rca connector and is used on some older tv's in place of a screw on connector.
if all else fails, your cable company should be able to provide you with a tuner/converter for free or minimal charge.
i hope this helps,
trin
Nov 16, 2007 | Hitachi 60SBX78B 60" Rear Projection...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
