Question about Bissell 1720-1 Little Green Wet/Dry Vacuum
It is leaking water from the tank and will not spray.
  • 2 more comments
  • Anonymous Mar 15, 2014
    bissell big green leaking water from flow indicator?
  • Anonymous Mar 27, 2014
    no water when depress spray button
  • Anonymous Mar 29, 2014
    how do I get the Bissell dirty tank clean
  • Anonymous Mar 31, 2014
    will not spray
    President:
  • 1,673 Answers
If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
Posted on Feb 29, 2008
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Managemyhome.bom does not spray
Hey Dennis, not having spray when you need it can be frustrating.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1196&cid=ccsocial
Feb 28, 2013 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Wont spray water
Here is a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1196&cid=ccsocial
If you continue to have no spray, here's a link to locating one of our Authorized Service Centers.
Nov 23, 2012 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Bissell little green steam cleaner 1720-1 manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 1720 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 29, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
There is a spring and a silver ball that seals the water from running out of the clean water tank, it fell out and I do not know how it goes back in. Bissel 1720 little green plus green machine
if it is from the tank,,,bad news,,, you have to replace the tank as a unit. according to the picture I see is an assembly and gives no parts breakdown on it exept the complete tank. there is a cover on top of the solution tank and is possible it goes there. that you can replaced but spring-ball part dont show on graphics. update.... cover is no longer available and tank price is about $23.00 at sears website part# 603-1204.
Good luck to you.
Feb 07, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
How to take full tank off
A great place to start would be the online User's Guides.
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number 1720 of your unit.
User Guide will be displayed as a PDF file.
Nov 16, 2010 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Bissell proheat 2x not spraying water
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell will spray water when set to water rinse, but as soon as it is set to light, normal, or heavy cleaning, there is no spray. I have tried priming but to no avail. I put plain water in the solution...
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Bissell 1720-1 Little Green Wet/Dry Vacuum Logo
1,215 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
