Question about Sony Cyber-shot DSC-W55 Digital Camera
Light seals on my olympus xa2 need replacing - Sony Cyber-shot DSC-W55 Digital Camera
  • 667 Answers
The biggest issue will be removing the old seals. Replacing the very thin ones in the door seams is not required. The large one along the hinge of the door is where most light leaks occur. A thin strip of felt will work as well.
Posted on Feb 29, 2008
What steps to take if water enters camera?
Try to record if it does not work probably its not worth fixing it.
Mar 11, 2015 | JVC GC-XA2 ADIXXION Full HD Action Camera...
I have an olympus 35mm camera that no longer advances. I have taken it to a couple of camera repair shops and have been told it cannot be fixed because parts are no longer made for this camera. Are you...
Unfortunately the repair shops are correct, and like many similar models the situation is made worse by the fact that your camera was never designed to be repaired or serviced. It was made to last about six years/100 rolls of film before being replaced. Professional repairers also won't touch your camera as it is quite literally worthless: customers tend to balk at fees which far exceed the cost of replacing the camera and so the repairer risks doing unpaid work with a very high risk of a subsequent unpaid warranty repair if the camera fails again shortly after being fixed..
The good news is that as there are millions of similar cameras lying unused you can replace it free or extremely cheaply. Many charity/thrift shops have boxes full and almost have to give them away, and if you ask on FreeCycle you'll usually get something comparable.
Virtually all of my camera gear has come from FreeCycle. The original mju or mju 2 are far more common than your model and are both excellent, although the same cannot be said for all Olympus compacts. The original fully manual Trip is superb, but the later models of the same name are poor. The XA and XA2 are excellent (especially the XA), but the later XA's aren't much good. If you want to try non Olympus models, then one astonishingly overlooked and underrated model is the Canon SureShot Classic 120. It's really high quality, has the option of spot metering, and the lens is simply incredible. They weren't produced in massive numbers but aren't rare either.
One other benefit of having a broken camera like yours is that you now have nothing to lose at all in trying to dismantle and find the problem yourself. It's unlikely you'll be successful, but you will gain invaluable experience to carry forward to your next repair attempt. You won't find any servicing manuals for the reasons given before, so will just have to use patience and common sense.
Aug 05, 2011 | Olympus MJU V 35mm Point and Shoot Camera
Olympus 1030 SW Camera leaked through both the battery door seal and the usb door seal. Did my best to clean it up and dry it out. Camera was finicky in at first. After a day everything work great...
I have the same camera and has the same problem. Mine flooded twice and when I followed the normal dry it out, clean the seals, charge the battery, etc, etc... I was left with a camera that didn't work at all after the second flooding. I returned it to Olympus where they had to replace the motherboard and seals. My dive buddy also has the same camera, dived deeper and has had no problems with his flooding or fowling. Olympus was very good about fixing the problem and returning the camera quickly. If you get fixed or end up buying another underwater camera, I would recommend after each use underwater, especially in saltwater, cleaning the seals and applying very sparing amount of silicon gel on the seals. The gel will help protect the seals and add to the tightness of the seal. But, don't let it cake up in the camera. I use the gel to protect o-rings on underwater video camera housing seals and have had no problems with leaking. You can get the gel at most SCUBA or hardware stores.
Oct 18, 2010 | Cameras
The front Panel on my Olympus 1030 sw is scratched, and the black paint is flaking off. Where can i get a replacement? It is no longer under warranty
Make sure you take it to a shop that can send it to an Olympus authorised repairer, as only they have the special tools to test the water seals after repair. Any camera shop who sells Olympus should be able to assist.
Jun 02, 2010 | Olympus Cameras
Olympus FE-330 I hit power on yellow light
I had the same problem.
The lens has failed and needs to be replaced.
Cost $US80!!!!!!
Time to buy a better camera, I'm afraid.
Oct 01, 2009 | Olympus FE-330 Digital Camera
Om4 light seals spares
If you can get a specific OM-4 light seal kit then you've done well as they're made of solid unobtanium with prices to match.
The job is not difficult on a DIY basis, just buy a suitable kit of cut to fit material and adhesive. Not difficult, but it can be fiddly...
I've been using kits from an eBay supplier in Japan for a while as his kits contain the correct type of foam, but I've now found one based in the UK who uses the same material with a better adhesive.
The first address is for a current listing. The second one is for the specific seller. You may find another trader who suits you better.
http://cgi.ebay.co.uk/COMBINED-CAMERA-LIGHT-SEAL-SELECTION-REPAIR-KIT_W0QQitemZ380129608842QQcmdZViewItemQQptZUK_Photography_OtherAccess_RL?hash=item58817d848a&_trksid=p3286.c0.m14&_trkparms=65%3A10|66%3A2|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
http://shop.ebay.co.uk/merchant/pilgrim18_W0QQ_nkwZQQ_armrsZ1QQ_fromZ
If you lack confidence to do this yourself, then get a pro to do so, but ask for a diagnostic check of shutter speeds first as OM-4's are notorious for circuit board failures. If it's jiggered then the light seal replacement is a waste of time and you should sell the camera for spares or to sit in a collector's display case and buy another.
Jun 26, 2009 | Olympus Photography
Olympus 790SW Leaks
You might want to call Olympus Customer Service to see if it is a part that you are able to purchase or they might tell you it might need to be sent in for repair. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 14, 2009 | Olympus Stylus 790SW Digital Camera
Need olympus master for FE-115
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
(http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version).
That sounds as if it may be a repair issue with the chip inside the camera that controls image processing. You may want to call Olympus Customer Service to discuss repair policy. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 11, 2009 | Olympus FE-115 Digital Camera
No Flash -- Olympus 710
This is actually a repair issue with the camera. The flash charging indicator switch needs to be replaced. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Feb 21, 2009 | Olympus Stylus 710 Digital Camera
Large, bright orange light streak in pictures
It does sound like a light leak, but hopefully all that has happened is that the foam seals surrounding the film compartment have perished and need replacing. With luck, this is unlikely to be expensive - check with your local camera shop or second hand camera dealer.
May 20, 2017 | Olympus Stylus Zoom 140 35mm Point and...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
