I cannot load my install for 3.5 usb hardrive although the drive is ok
    Master:
  • 518 Answers
Unplug the drive from the usb, Install the software, reboot, then plug in the usb cable. You didn't state info on the drive, but you could check their website for an update.
Geno
Posted on Feb 29, 2008
I have protools7 that wont load after I installed porsche design lacie 500gb hardrive
USB 2.0 is extremely slow for the purpose of doing direct recording. External drives are best used for backup after a project is done.
Dec 27, 2014 | LaCie 500GB PORSCHE DESIGN P9220 USB30...
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
The Hardrive is now beeping and the blue light only flashes once. And my laptop isn't recognising it. Everything I have is stored on it?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 24, 2012 | Buffalo Technology Buffalo MiniStation...
Hi , i have a 500gb hardrive i bought a few months ago, full of family memorys and although it powers up the computer has stopped or failed to regonise the hard drive , pleaser can you help .im desperate
Replace the cable you are currently using with your printer cable and see if it is the cable if that is not the case I would open the case, and check your connections on the hard drive, there is a chance it might have come loose.
Jun 23, 2011 | Genica 2.5 USB 2.0/eSATA Aluminum External...
Laptop hard drive
If you have reinstalled windows, on this hardrive using a different computer, it would not load into windows on the nortino 6770, because the windows now has the settings compatible with the other computer not this machine.
To get around this problem, you would have to reinstall windows, by placing the haddrive in the 6770 only. To do this , you can either copy the contents of the windows cd , to a flash drive or pen drive ,and then connect the same to the USB port of the laptop.
The other way , is connect an external USB cd drive and install the same.
Best of luck
Proton
Oct 11, 2008 | Balance CN6555 Notebook
Simpletech external 500GB Hardrive corrupted
PC INSPECTOR™ File Recovery 4.x is a data recovery program that supports the FAT 12/16/32 and NTFS file systems. The current version 4.x replaces the previous version 3.x, which is now over 6 years old.
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
Aug 03, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Downloading...
ok..no worries.
go to www.lacie.com and look for support downloads..then your model number and o/s..
should do le trique, n'est pais?
and you might consider backing your ext drive up with this option, too...
Mar 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Usb connection failure
ok" take a small needle , streighten the pin very carefully.
Jan 21, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
