When I put my memory card into the CPU and try to download the pictures, the computer tells me that the device is not connected. I have downloaded many pictures before with no trouble. My camera is a Fuji FinePix A310. Any help would be appreciated.When I put my memory card into the CPU and try to download the pictures, the computer tells me that the device is not connected. I have downloaded many pictures before with no trouble. My camera is a Fuji FinePix A310. Any help would be appreciated.
AnonymousFeb 07, 2009
i just vdo not know how to do thisi just vdo not know how to do this
You can't post conmments that contain an email address.
Re: I cannot download my pictures the camera( d70) works...
We need more information to help you.
Did you install the sowtware? Did it come up with any errors when the software was loaded? What operating system are you using? Did it ever work correctly?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire. Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera. If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
I found this on another site. You have to set the camera itself to Mass Storage mode in order to work with Windows 2000. The steps are below. As soon as I did and plugged the camera back into the USB cable, Picture Project recognized the camera as connected, installed the mass storage driver for it and requested a restart of the PC. Able to access the memory card and download pictures.
On the camera itself, unplug the USB, turn it on and...
Press MENU.... Press ▲▼to choose SETUP...press OK... Press ▲▼to choose INTERFACE...press OK... Press ▲▼ to choose USB...press OK... Press ▲▼to choose MASS STORAGE...press Ok.. Press MENU to exit...
Then plug it back into the USB cable.
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X.
To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
