Powerbook g4 - la cie 500gb doesn't mount.
Just bought this powerbook G4 (arrived in Japan, didn't want to bring my g5 tower over). It won't mount my la cie 500gb. La Cie was brought over lovingly, so disk or other failure seems a bit of a coincidence.
It doesn't recognise the partition, sees a '2TB' disk. Tried installing OSX 10.5, to no avail.
Any issues you know of?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
No, but why not ask La Cie? They have pretty good support, and if your computer isn't recognizing it, you can feed them all the information they need by downloading a freeware program called Balarc advisor, which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have, go to
http://www.lacie.com/support/faq/faq.htm?faqid=10338 You may need to download something from them for your poswerbook different from your g5..
Posted on Mar 09, 2008
    Novelist:
  • 104 Answers
Either your HD is broken or you this is the first time you install a new HD... and there are some details like what kinda cable youre using and if that HD is jumped correctly... so, just in case you feel a little clueless:
1. Make sure your G4 supports that exact HD by calling MAC.
2. Make sure you have the right data cable (one that allows you to use it at its full transference speed and of course that is supported by the motherboard, all things that MAC will tell you).
3. Make sure your HD is jumped the right way, many HDs comes without a jumper but it does not means that they are not necessary in any case. (To jump it right see instruction manual on HD company`s website. If you are clueless in this part, call the HD`s company, phone or chat is always better.
4. If everything above is right you just have to get Partition Magic or Paragon Partition Manager, out of the Internet (just look for it, its very popular and simple), burn it inside a CD and boot up with it. (in case you ve never done a thing like that, just take any bootable CD you have or can find, and add this PM or PPM program to the CD,... of course in a new copy of that bootable CD, with the additional PM inside and once you boot, you will be able to path to that folder and run the program...) Partition Magic comes for windows too... so you will not need to boot from any CD.
IMPORTANT: if you cannot find PM or PPM for MAC you will need a PC with windows inside...
if you are sure you have no problems nor lack of stuff just run partition magic and do anything you need with the HD, latests versions also have a way to partition for OS systems...
in any case, if your system or motherboard cannot detect the full HD space, try "cheating" by just using the space you can for installing and then format the rest of the HD with PM or PM from windows or DOS.
In the worst case... use the HD that comes with the G4 if you have it, otherwise buy a little one that does not have that problem and install OS in it. Then just get a external case for your big HD connect it to the mac by USB or Firewire and use it for DATA storage, IT IS ALWAYS BETTER to separate system from data.
and next time remember, MAC is great to work but not to upgrade it...
Good Luck
Posted on Mar 10, 2008
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Can't connect to a second internal hard drive via network on MAC
Mac OS X will not file-share any non-HFS volume over a network. However, you can set up such sharing manually if you are willing to use the command-line interface by following the detailed instructions at
http://www.macosxhints.com/article.php?story=20090216180227216
Mar 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
PowerPc to an intel proccessor.
The G4 powerbook Im typing this on is running 10.5.8. It is only snow lepeord that is intel only.You cannot upgrade the g4 chip.
Oct 18, 2009 | Apple iMac G5 Desktop
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Jun 15, 2009 | Apple PowerBook G4 Mac Notebook
Will virtual pc for mac v7 work with powerbook g4 running 10.4.11
Sorry, but the G4 and G5 desktops have chipsets released prior to the Intel agreement allowing pc's with CoreDuo and Macs with DualCore chips to exchange data, even though Virtual PC for G3 through G5 chipsets did work in running MS OS's prior to Vista, including XP, on mac platforms.
Now, if this helps, you might be able to secure an older version of Virtual PC, since your version works on current Macs and PCs with Vista, to run XP on your G4 and G5.
Mar 24, 2009 | Microsoft Virtual PC 7 with Windows XP...
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Dec 10, 2007 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
300 people viewed this question
David Payne
David Payne
