Question about Dishwashers
Beco D 3422
The dishwasher does not fill with water but emmits a bussing noise when switched on. Why?
Any simple solutions or is it the water admitance valve.
How can I order spare parts as I live in a remote area and repair men do not want to come over here.
  • 2,336 Answers
Check HERE for info on how to DIY.
Posted on Feb 29, 2008
  • 4,889 Answers
    Master:
    Sergeant:
  • 462 Answers
Hello sir
  • Mohamed Ismail
    Mohamed Ismail Feb 29, 2008
    Sir please check the water admitance valve tell us.
    Thankyou....!!!!
No water on start up
This is an old question, but my answer may help someone. I experienced the same after having had a new dishwasher installed. Switched it on, it made all the humming noises, heard running water then nothing. Simple solution was on checking the plastic plug was still in the drain spigot and the hose had been connected over the top of it so no water could drain away.
May 05, 2012 | Maytag 24 in. PDB1420 Built-in Dishwasher
The dishes and glasses are not clean after the cycle, and there's lots of white coloured water in the bottom of the machine after the cycle. Is there a way to improve the quality of the wash that...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Dishwashers
Machine is not filling and making a hissing noise
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 13, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher not filling with water. Humming noise.
Hi
Daniel
Jan 08, 2011 | Bosch 24 in. SGS43C12 Classixx...
When we turn on the dishwasher there is no water entering the appliance..then it cycles to drain the water and I reset it so the pump doesnt burnout...what could this possibly be and is there some...
hi Mapletonmob.
this is all i could find out.
A dishwasher that will not fill with water can be frustrating and repairing it through a serviceman can be expensive. Even for someone who may not consider themselves handy, repairing a dishwasher is not a difficult process. Below we've provided you with a list of the most common parts that fix a dishwasher will not fill with water. Use this information to help troubleshoot which part is broken
The water inlet valve is used to fill the dishwasher with the proper amount of hot water and is controlled by the timer or electronic control. The valve will be located behind the lower access panel and will have two wires attached to it, an outlet hose to the tub and a hot water inlet from the household supply. If your dishwasher does not fill then you should first check the inlet supply to verify that you have enough water pressure and that you have power going to the valve during the fill portion of the cycle. If these conditions are met then the valve is defective and should be replaced. If you do not have power to the valve then you should look at the float switch, the timer or electronic control or the door switches as a possible problem. All of the electrical checks can be made with a multi-meter.
A malfunctioning float could cause the dishwasher to not fill with water. The float is located at the bottom of the dishwasher tub and acts as a safety device that prevents the dishwasher from over filling with water. The float rises with the water level in the dishwasher and when the proper level is reached, the float will trigger the float switch to turn off the water inlet valve. Check that there is no debris or foreign objects that might restrict the vertical movement of the float and that it engages the float switch located beneath the tub.
The float switch sits below the float, beneath the dishwasher tub. When the float switch is triggered by the float, power to the water inlet valve is interrupted and it stops the flow of water into the dishwasher. Verify that the mechanical action of the float to the switch is operating properly and that the wire connections are secure. To check that the float switch is working properly, remove the wires and test for continuity with a multi-meter.
The door switch is a simple on/off mechanism that prohibits the dishwasher from operating when the door is open. If the door switch or switches are malfunctioning the dishwasher will not fill with water. This door switch mechanism is typically located behind the door panel at the top of the door. To verify the operation of the switches you will need to separate the inner door from the outer door and then remove the wires from the switches and check for continuity with a multi-meter.
We've identified the most common parts that can cause the dishwasher to not fill with water, but there are other parts that could be at fault. If you are unable to fix your dishwasher with the information above,
if none of the above work you might have to call someone out to have a look at it.
Nov 29, 2017 | Maytag Dishwasher
Dishwasher doesn't want to fill with water...float switch acts opposite of what it should....when I depress it the water solenoid activates and fills. Is this normal or could there be something else wrong?
if the switch is working opposite of what it should be doing then it is shorting out inside and needs replaced its as simple as that so replace the switch.the only other thing that could be wrong is if a wire has come off and the circuit is not complete.adrian,,,,
Dec 03, 2010 | GE Adora GHDA650LBB / GHDA650LWW Built-in...
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Dishwasher not filling completely
Sounds like the float switch is out of adjustment,(or the retaining plate is loose) The float & switch are located toward the front of the tub.You can access the switch buy removing the lower panel on the front of the washer.
Jan 07, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water won't fill and makes a loud noise
if it is not filling, but continuing the circuit, the first thing i would check is your float switch make sure its not stup up
or remove the toe kick and look under the machine
and you can check the switch the float switch sits on under the machine
Oct 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
My JennAir JDB5900AWW won't fill with water. It
here is the solution to your problem
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 07, 2009 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
