-   i have a phillips 30 in flat tvlcd i purchased in 2005.model # 30pf9946/37 i have sound but no picture. when it is off the red light is on . when i turn it on it goes to yellow then green a flash of light then nothing. please help.-   Guest
Not enough input (info) or u using cable connection or av, if av could be the signal not going in,
Bad convegence so goes into protection,
Bad vertiacal so unit goes into protection.
Bad high voltage block so no voltage to crt's
Blowed Horz transistor, so no difflection.
If seen some RCA with this problem deppending on your model..
If seen some mitsubitchi with bad ic's but dont' know your brand.
If seen sony with shudown defflection for burt resistor in power supply but can't tell no model.
You see I can gess all day but without the info, well I could be talking of a monator.
(Bradyjr4) sounds like you could have one of two different problems . Possible bad inverter module that regulates the picture for your display panel or problems in thr power supply . Without a meter or knowledge of how the set works this could be tricky to fix . But one of two would be your problem . For the (Guest) it sounds like a bad power supply board and your tv is going into shut down . You would want to confirm the secondary voltages are present before turn on to confirm this board is bad .
Power Light continuously blinks with no picture or sound. The Ballast and S2 Board have been...
(More)
Power Light continuously blinks with no picture or sound. The Ballast and S2 Board have been replaced. Techie is not sure what to do next.
Where can I get a user manual for the Funai 29B-250 video recorder? The channels are all in the...
(More)
Where can I get a user manual for the Funai 29B-250 video recorder? The channels are all in the wrong order and I cannot see a way to re-order them.
my toshiba active vision 100hz dynamic frame scan 50" projector television's picture is not...
(More)
my toshiba active vision 100hz dynamic frame scan 50" projector television's picture is not right ive tried to adjust the settings on the tv and i can get the colour right but lines keep going accross the screen could you possibly help please
sony rear projection tv kp-65wv700 7 blinks on indicator light.how do i fix it. turns on blue fades...
(More)
sony rear projection tv kp-65wv700 7 blinks on indicator light.how do i fix it. turns on blue fades to green than pink then screen goes black.
