Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I formatted my 2.0 cruzer mini usb drive
Cruzer mini 2.0 gig usb drive
    Scholar:
  • 64 Answers
Hi lapigota,
I'm not sure what your question is here. Please go into detail and we can help you out.
Ben
Posted on Mar 05, 2008
How do i remove write protection on a sandisk cruzer 16 gig usb device
Format it with your windows format tool then right click on it in the device control screen select "run as administrator"
Oct 07, 2014 | SanDisk Cruzer Edge Sdcz51-016G-B35 16 Gb...
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
When I insert the USB it reads error 23. How do I solve this
  1. Copied all the files that came with the Sandisk device to another location (in case I need them again)
  2. Copied all the music I had put on the Sandisk since I got it to another location
  3. Using a Windows PC, I right clicked on the drive in Windows Explorer and selected "format"
  4. I re-formatted the cruzer mini to FAT 32, default size (yes, I know it was FAT 32 already)
  5. Copied the music back to the cruzer mini
  6. Plugged it into my radio and it works GREAT! instant access to any track
Before you do this: Reformatting the drive also gets rid of the software that makes the cruzer mini copy files super fast. It will take a lot longer to copy music to the drive
Dec 16, 2009 | Vehicle Parts & Accessories
4GB ScanDisk Cruzer Micro was working fine now the storage capacity displays 2x 68MB drives dispite being formated.How do i restore it back to 4GB.
access the drive through administration manager and delete any and all partitions. Then create a partition for the full 4gig drive, reformat and that should give you back your full 4 gig.. Just make sure you backup anything that is on the drives BEFORE you delete the partitions.. administration manager is located in the windows control panel. MAKE SURE you are accessing your usb drive when you delete the partitions as once you delete them you can never get them, or any info on the drive back. If you accidently delete your hard drive partition, you will have to start again with your operating system from scratch.. SO BE CAREFUL...
Nov 02, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have the exact same problem.
Fat32 File system is limited to just under 4 GB. I've tried to format using a different file system but no success.
This isn't really a solution but at least it explains what's happening.
Jun 07, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I had a 2 gig cruzer drive that flashes 3 times over and over and then goes solid. I can not open it.
Pocket Fuzzies?
Get a bright light and look into the USB connector of the Cruzer. It is possible that there is lint, paper bits, cookei crumbs, etc in there and that is your problem. The outer 2 connections of the USB is DATA and the inner two Power. B/C it is able to flash,you are getting power... but the data lines may be dirty, covered, bent, etc.
Clean it up and try again. Flat toothpick, small ty-wrap or Proxident (dental/braces) brushes work well for this - DO NOT use anything Metal!! It will scratch the connectors and vastly shorten their life (they are GOLD plated)
Short of that, goto HP site and get their USB format tool (get it here: http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Jan 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer mini 2 gb
There is no drives required for detackting the drives it automaticaley it detact so please check the usb port are fit in your system.
Jul 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk u3 micro 1 GB Cruzer
hi turn off your pc put the card into the usb then turn on your pc let the pc find the drives for it and load on if this dose not work try the same in another usb port ok
if it works you must format the 1 gig stick befor you use it
ok hope this helps
May 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Loss of memory
TRY FORMATTING FROM MANAGE OPTION....AND SEE IF IT WORKS OUT.
Apr 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
88 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
