Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Sportster 4 Just received a new Sportster 4 as a gift. The unit will not activatebafter 6 attemps with Sirius reps. My old ACT unit was deactivated with no problems. Is there a fix short of geting a replacement unit?
  • DickL Mar 04, 2008
    Yes, I went to the menu, but to no avail.  I called a Sirius service rep and  she quickly gave me an RMA# and sent out a new unit which activated with no problem.  Great service.
    DickL
  • 20 Answers
Dick,
Did u go to the menu to get the Sirius ID# or ESN# or did u get it from the box or back of the unit itself?? I used to work in activations department for sirius and the most common reason that a plug and play unit would not activate is a mismatch in ID #'s. I have seen units with one ID number, but the box or the back of the radio actually being labeled with a different number. By the way,only one signal can be sent to the radio every 20 minutes or so and most reps you talk to don't even know this. So after sending the first signal, all they are doing is clicking a button on the screen and getting a message back that says "Duplicate Provision" meaning that the signal cannot be sent because it is already sent. If you were hearing audio on channel 184 when the signal was sent and you made no adjustments during this time, and the SID or ESN number is the correct one for your unit, and the radio doesn't activate, I would get a replacement. But this never happens in my experience unless there are other signs of defect.
Hope this helps!!
Posted on Feb 29, 2008
Radio plays upon startup but withing minutes message says searching for signal then antenna not found. replace antenna?
No, it's the Sirius Tuner. If it's 2 or so years old, there's a bad ground on the antenna port pc board. If your tuner is roughly 6"x6"x1" it's the one. The new tuners will not have this issue and are considerably better built. (DEI) is the manufacturer of the new unit. If you don't mind rebuilt, you can save 40 or 50 on a repaired tuner. The repaired tuners are very reliable since they upgraded the board with one that's durable. Hope this helps
Dec 10, 2009 | Sirius Satellite Radio Receiver
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
Sportster does not work
The issue will have to be the sportster unit. It would be too much of a coincidence for bothe the car cradle and Boom-Box to have something wrong with them. I have seen this before...most of the time, the connections on the sportster will have a bad solder joint. This will cause it to turn on and off intermittently. You can confirm this by wiggling the unit when it is docked and getting it to turn on and off. This is not something that would be easy to repair as you will want an electronics repair to fix. The Sportster comes with a 1 year warranty from the manufacturer, so if it is covered, then you can get a new tuner and apply your old subscription to the new one.
Sep 25, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
No Power...Keep Blowing Fuses
you have a live going to ground meaning a live wire is touching another wire or touchin the caseing thus blowing your fuses
regards Doug
Feb 29, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Feb 15, 2008 | Sirius Satellite Radio Receiver
Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
Feb 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius Sportster 4 Problem
sell it or so many of the units run into this problem and nobody knows how to fix it.
Sep 25, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
176 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
