Yamaha AV Receiver RX V-995
I own a 5.1 Yamaha AV Receiver RX V-995. When I put the Power switch on only the LCD on volume lights up & the moment I leave the Power switch it goes off. In short the Amp does not come on.
  • spidey327 Mar 30, 2008
    My problem is similar on my Yamaha HTR-5590. The amp will turn on and work for awhile then shut off. And then after pressing the power switch it will momentarily make the power on relay but the channel relays never come on before the power on relay turns off. But then eventually it will work ok for awhile. After unplugging everything I can't get it to fail.
You may have a problem in the primary stage in your Power supply !! Unhook everything that is attached to it .... make sure the power plug is in good shape and you have the right amout of ac at the plug and good grounding ... then then try turning it on again ....
Does it stay on ??
if not .. there is something wrong probably in the primary stage of the Power Supply ... could be a bridge or something like that
hope this helps
Posted on Feb 29, 2008
How to power up av receiver
Connect the AC power chord provided with the Receiver and switch-on power - the standby indicator glows now press the standby switch to power on your receiver
Jun 20, 2015 | Yamaha RX-A1020
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
My yamaha recever when I turn it on goes all the way up.I mean the volum everytime.Im not sure but did someone set it that way?
Yes, yamaha receivers can be configured to a specified volume level on power-on.
For my receiver it is at Setup menu / Func. setup / Volume / IniVol.
Mar 07, 2010 | Yamaha RX-V461 AV Receiver
Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Nov 06, 2009 | Yamaha RX-V550 Receiver
Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
Nov 19, 2008 | Yamaha RX-V995 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
246 people viewed this question
 Grubhead
Grubhead
