JVC AV36870 TV (36
I picked up this 36" beast at no cost. Its in perfect shape. Owner told me it would not power on via the front panel switch or the remote.
Any ideas where to start looking? I have not tried it myself yet, nor have I opened it up. I am an electronic engineer and reasonably well equipped at home with test equipment, although my strengths are more radio/audio.
Thanks
Ian R.
  • va2ir Feb 29, 2008
    Thank you for the advice. I will be checking it tonight
    Ian
  • va2ir Mar 12, 2008
    I did fix it! All these TV;s have problems with 2 electrolytic caps in the stand-by power supply. C926 and C928. I changed them both and the set works like brand new! Not bad for a freebe.
    Thanks for all the help. Great site
  • 2,336 Answers
I would suggest to try checking the fuses first, voltage regulator(s), horizontal output transistors and lastly the flyback transformer.
Check HERE for some more info.
Posted on Feb 29, 2008
Hi there I have a jvc tv 'LT-42X788' when I power on the cbc sign comes on I here a click and screen shuts of there's a blue light that came on when I power on it stays on any help thanks
@Thomas Scissons
"JVC LT-42X788 display fault..."
Hi Thomas.
Please pick one:
Power supply board (possibly a blown capacitor):
A TV-tech can repair at reasonable cost, less than a new set.
The main board itself has a control / display section fault:
The screen / panel is shot:
Beyond economical repair - renew set.
Hope this helps.
Clive.
Oct 16, 2017 | JVC Televison & Video
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
Problem with the JVC AV-36D503 36" TV.........TV will not turn on. Bought TV New in June of 2003...Dec 2003 the TV went Dead...They replaced the Safety Fuse. If same problem would you have any idea...
Tv might have more dead parts than just the safety fuse.If tv have only a power supply board fuse only they can do it for u wright there take the tv aparts and replace the tv power supply safety fuse like 15 mins job and will cost u like $40 dollars take it to any tvs repair shops.
Aug 25, 2011 | JVC AV-36D503 36" TV
Tv just shut off and won't power up. No lights nothing. Tried unplugging and plugging back in. There is power to the outlet. I told my dad it was toast.
You are correct. If you get no image or text from the screen indicating it is trying to operate then it is time for replacement or service.
Sep 25, 2010 | JVC AV-36D800 36" TV
Jvc- 36f702. Powers up then shuts down right away and the red led blinks on the front panel?
Dec 03, 2009 | JVC AV-36F702 36" TV
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
Jan 05, 2009 | JVC AV-36D303 36" TV
36" jvc tv start button flashing
you must hit the input button on the side of the TV until your input is detected.
Apr 30, 2008 | JVC LT-32X576 32 in. LCD Television
JVC 36
Most of the time the cap you speak of tends to buldge at the top of it . The spark you speak of is just the two contacts joining . With the tv unplugged you can clean them with a fine sand paper and blow out any dust if you think this is your problem. The picture tube would not cause this problem , Only real way is with the tv on and looking at the pictures brightness and color . Also this tv shuts down due secondary shorts - vertical problems - horizontal problems . Any more help after you check it out let me know . Good luck
Feb 29, 2008 | Televison & Video
Video swiching
have hook up to front av ports and tried to switch from video 1&2 and no change. To add to the problem it doesn't switch to video 2. thanks!
Apr 15, 2007 | JVC AV-36D503 36" TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
