Question about Kitchen Ranges
Is there a technique for replacing a broken oven door hinge on my delonghi dfg 903 oven door. I've got both parts into position put can't seem to hook it in properly and secure it. Appreciate a leg up before the wife gets in. thanks Steve
  • 1 more comment
  • barneseyo Feb 29, 2008
    Hello Paul.
    Its a Delongi dfg 903
    Sorry I've been a while. Yes your right. Its a spring mechanism that stops the door from going over 90 deg.
    Thanks for your effort but I've done that. Its a complete swine and I've eventually done it by more or less dismantling the outside panel of the cooker itself and brute force. Take care and thanks agian
  • 4,102 Answers
What is the make and model then i can give you the instructions you need and talk you through the process
Posted on Feb 29, 2008
  • 2 more comments
  • paul proctor Feb 29, 2008
    Hi is the hinge you brought the male hinge or other as i cant find your exact workshop manual for you rmodel
    has the hinge your repalcing got a piece sticking out with a sort of hook om it
    Hi it looks like the best way of doing this si to remove the oven door completely from the oven undo at both hinges undo it from the oven itself leaving the hinges in the door then once the door is off you will be able to see where the hindge is held onto the door.
    So undo door from the oven completely this will make it easyier for you to work on as well as its easyer to remove the hinges from the door when its off the oven let me know if you get me this far
    Hi sorry i thought the door was still on the cooker sorry my fault glad you got it sorted though
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
Oven door not sealing correctly on our A106G Delonghi oven. It is sitting out slightly at the top
One of the door hinges may have come off track at the base of the door. Need to release the clamp on both hinges and get the door out for inspection.
New hinge can be got from
Delonghi Male Oven Door Hinge
Sep 03, 2014 | Ovens
Oven door hinge
Could you take a photo of the oven, the door and the hinges and show us?
Feb 14, 2014 | GE Microwave Ovens
Can i adjust the hindges as my door does not seal closed i have a delonghi pro cooker ess903 thanks colin
It is usual to be able to adjust oven door hinges.
Normally the only solution is to replace the hinges.
Hope this helps.
Jan 12, 2010 | DeLonghi Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Nov 29, 2008 | DeLonghi Kitchen Ranges
Door gapes open
My door is the same you can get a hinge for it 17.99 online at Currys I believe. Google the oven make and then parts.
Sep 27, 2007 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
