Question about iLO (2 GB) MP3 Player
Ilo LCD screen Burn
It appears that the Sigmatel part underneath the LCD screen
has latched up, as the LCD shows a definate burn spot.
The unit was functioning properly, then I noticed the screen, and
it wouldn't function any more. The backlight was on all the time.
Have any other people had this problem?
Thanks,
Tim
  • Tim301 Jul 06, 2008
    It's pretty obvious that the player was non-repairable, was just curious as to whether anyone else had seen the problem.
    Thanks,
    Tim
  • 8,596 Answers
Replace - not repairable
Posted on Jul 05, 2008
  • Corey Knoettgen
    Corey Knoettgen Jul 06, 2008
    Actually, that one is extremely rare
  • Corey Knoettgen
    But these are officially the worst mp3 players ever
LG 55LF6300 Black spot and picture freeze every few seconds
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 03, 2017 | LG Televison & Video
Is there any way to get rid of shadow marks or burn spots
Burn is is usually permanent(must replace panel, NOT cost effective)
You may have a screen position in your menu to try to wipe it, where the screen stays all white or wipes across screen from black to white to try to clear it) If it is burned in bad enough now it is too late.
May 06, 2014 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My garmin 60csx started to smell like electric burn. It then showed a burned spot on the screen. IF the backlit light is off then the burn doesn't show but if it is on, then it shows a burned spot in
Should it not be 12volts? If its really 250 volts i garmin shouldnt switch on anymore. And actualy use android and google maps in it. Garmin is useless anyway
Feb 25, 2018 | Garmin GPSMAP 60CSx
My samsung washer WF316LAS/XAA has a e3 error code I took the stator off and you can see a smoke or burn spot on it do you think that's the problem?
almost definately. check the resistance across the windings of the stator. they should all be the same. (which they almost definately won't be if theres a burn on there)
Nov 07, 2013 | LG WM2016C
There is a brownish spot near the bottom of the screen - almost looks like a burn spot about 6" by 2.5" on my Samsung LCD 40" tv screen.
U have a burn in image to LCD screen panel like display the same image too long like hours in and out.Sorry this problems,have to live with it.Can't remove burn in images problems.
Mar 22, 2011 | Samsung LN40B530 40 in. LCD HDTV
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
Seem to have locked the monitor in burn in mode
This problem is a failure of the control circuit of the logic section of the monitor. The control circuit has latched on this function due to failure of some component or the control itself.This problem requires you to return the unit for service at the dealer or take to service center. Hope this helps.
Mar 11, 2009 | Envision 19" Widescreen Flat Panel LCD...
LCD T.V. burn-in question.
I can assure you that LCD burn in CAN and DOES happen! My frequently-viewed Futures Trading software has left a ghostly image of the toolbars, menus, and window borders on my ViewSonic 36" LCD flat-screen.
Apr 24, 2008 | Televison & Video
Ilo LCT32HA36 LCD TV
HI, I AM JESSICA PORRAS. I PURCHASED AN ILO PLASMA 42" T.V. FROM WALMART IN 2006. THE T.V. LASTED 1 YEAR AND POPPED A FUSE. THE SCREEN WENT BLACK, BUT VOICE IS STILL COMING THROUGH. I DID HAVE WARRANTY AND MY MONEY WAS RETURNED. I HAVE A QUESTION AS FAR AS THE BRAND 'ILO' GOES. CAN THE PARTS BE CROSSED WITH ANOTHER BRAND? SINCE THE FUSE HAS POPPED, WE HAVE REPLACED THE FUSE 3 TIMES, AND IT KEEPS POPPING THE FUSE. THE LAST 2 FUSES HAS BEEN A CERAMIC FUSE AND IT WILL BURN THEM. THERE IS A SHORT AND WE ARE WANTING TO CHANGE OUT THE TRANSFORMERS. IF I CAN HAVE A TECHNICIAN CALL ME @ 432-553-6784cell OR 800-880-2817work M-F 8-5PM CST. YOU CAN ALSO RESPOND BY E-MAIL. THANK YOU, JESSICA PORRAS
Feb 04, 2008 | iLO 3200 32 in. LCD Television
iLO (2 GB) MP3 Player Logo
159 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
