Question about Maytag Neptune MDE5500AY Electric Dryer
Not drying no heat.
The dryer operates just fine but all of the sudden it quit heating. Could it be we need a new heating element and is it hard to replace.
  • greganddiana Mar 08, 2008
    no heat all of a suddden
  • niknac Mar 18, 2008
    We have an old Maytag Dryer Model# LDE412 It will not heat up. Trying to figure out how to get to the heating element.....help! Nikki
  • 156 Answers
Be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Posted on Feb 29, 2008
Haier dryer rde350aw not drying?
The heating element probably needs to be replaced. The are not hard to fix or very e
Aug 07, 2014 | Dryers
BEKO TUMBLE DRYER NOT HEATING UP
Hi there
You haven't said how old the unit is.. After some use the heating elements get brittle, which is not really a problem until you physically move the dryer, as in moving house. Any sudden bumps and the brittle elements will just disintegrate.
Replacing with new (quite an easy operation) will rectify the problem. If the whole dryer was new when you moved then maybe BEKO will replace under warranty.
Good luck
Nov 24, 2017 | Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Dryer won't heat
The back panel doesn't come off for service!!! Most heating and control components are available behind the kick panel below the main dryer door..
With electric dryers my normal train of thought in diagnostics is to start with source of power. Do I have 220 volts available at the terminal board where the electric cord is connected??? Quite often I find a blown fuse, etc to cause it to stop heating as the motor will run fine on 120 volts as thats all it requires, but the unit will not heat with out 220 volts to the element..
best of luck, and have fun,
ttfn
Feb 02, 2010 | Kenmore Dryers
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
No heat, will not dry
Is your dryer electric? Assuming so, you're probably right that the heating element has gone out if the drum is turning but there is no heat at all.
I don't know if you are a do-it-yourself type, but if you take the model/make/serial info to your appliance parts store, you can obtain the correct heating element and install it yourself.
I hope this helps... Good luck!
Oct 23, 2009 | Dryers
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
219 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
