My classixx 1200 started washing and then about 5mins into it it went a bit haywire. The lights flashed and it made a noise as if it was finished.When i tried to put it on again the lights go on and it engages but no water seems to come on and you can hear a noise, sounds like the motor is going? but nothing happens
Try turning the tap on.
Posted on Mar 18, 2008
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
