Water valve has to be shut off at wall faucet to prevent tub from filling and flooding out into room when door is opened. Washer does not always spin all of the water out of the clothes (or possibly more water has just run in tub when clothes have not been removed immediately after wash).
This may be caused by a pressure switch malfunction or a water inlet valve that is leaking by. The following link explains how you can determine which one may be causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Is this a simple problem of the washer continuing to fill with water when its not in use? Does the washer overflow? Does the water shut off after the cycle ends? These are some good questions that can help lead you in the right direction.
Check the small air hose that runs from the bottom right hand side of the wash tub to the pressure swtich. If this hose has come loose from the pressure switch from the air dome on the wash tub, the pressure switch will not sense the pressure differential coming from the wash tub as the unit fills. Also, if the air hose is cracked, ripped, split, or clogged somewhere, you will get the same symptoms.
If the water inlet valve is determined to be the source of your problem, follow the steps provided in the link on how to replace one. These are simple and inexpensive repairs. I've also included web sources that you can refer to for part numbers.
If you need further assistance, please post back and let me know. I hope this helps lead you in the right direction.
I have found that when I had this problem with water valves in washing Machines in the Launderettes that I serviced the problem was usually
that the water pressure was too low to keep the valve shut after the power was shut off by the timer, Due to A:clogged inlet filter B:spring inside the valve sticking due to corrosion or scale.
Strip the valve and clean.
More remotely...the timer giving a rogue electric feed from a faulty timer.
Hopes this helps.
