Question about Refrigerators
Westinghouse Fridge problem
Hi i have a three door westinghouse fridge which has been working fine all these years but recently i experienced a wierd problem where the freezer as well as the centre section which works both as a fridge & a freezer are working fine but the lower fridge has just stopped cooling. It is just suprising how this has happened. Could u guide me in this. Thanks a ton. Rohit
  • 236 Answers
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Posted on Feb 29, 2008
Have purchased a westinghouse aurora double door fridge frezzer second hand in the middle off doors its very warm and the fridge side doesnt seem to be as cold as it should be. Frezzer side fine any...
There is a heating coil in those for defrosting purposes. You need to check and see if there is a defrost timer and see if it is stuck. Since you did not post the make and model number, that is as far as I can advise
Oct 27, 2017 | Westinghouse Refrigerators
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Hi I have a Westinghouse WSE7000SA refrigerator witch is about 3 years old now & it has just started playing up? It seems to be working fine but only some times when you open the fridge door the light...
You have a short, check you outlet, cords and all connection. Start at the wall and go from there. Try a different outlet. It made not be the fridge.. Good Luck
Aug 01, 2014 | Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Jan 16, 2010 | Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
