Question about GPS
We have got a ravenheat combi csi85 its just 2 years old now the flame failer light keeps coming on and their is no heating or hot water we have had 3 corgi people out and thay say there isn't any thing wrong with it we have 2 young children and its doing it all the time we are losing patents
  • Anonymous Mar 21, 2014
    hi i have a ravenheat 84et
    combi boiler the heating is fine but when you turn the tap for hot water after a short time you get this noise sounds like a airplane diving and just get loader and loader it sound like it coming from the top part of the boiler were the fan is but the fan works ok when the heating is on no noise any help i would be grateful andy
This boiler doesnt have a pilot light dude, make sure you know what type of boiler it is before you give advice on them ;-)
Posted on Dec 17, 2009
  • carlthegit Dec 17, 2009
    i personally would be looking to see wether the pump runs, fan starts and go through the combustion proccess. if you are just getting a power light and nothing is happening, then usually this is down to the thermistor being faulty, i have come across this problem a few times. if the pump runs fan starts then stops again, i would suggest looking to the air pressure switch. :) hope this is helpfull
We have a revenheat csi 85 and the hot water is not coming through very hot what could be the problem
Posted on Nov 07, 2010
    Genius:
  • 1,019 Answers
Well you can,t get better than a Corgi-Registered Gas Fitter.
So they say, if the flame failure light keeps appearing, theres obviously A Fault. But this Can relate to several Issues.
1:) The flame is physically Failing, due to air being sucked into the Case. ( causing the pilot to Fail ) Unless it,s auto-ignition upon request. Lights only on demand if hot-water tap or C/H calls for heat.
2:) This Is more Common, Thermocouple failure. This is the device, that under heat from the pilot light, informs the Main Gas Valve that everything is ready to Go. If a thermocouple fails the main gas Valve Will refuse to open, and supply Gas.
3:) Most Likely Is A PCB Circuit or relay problem, The Printed circuit board controls most of the Boilers Functions, there are many relays and solenoids on-board, to shunt the diverter valves from C/H To Hot Water et,c. et,c.
Solution:- If the pilot light can actually be seen as Lit, through the viewer glass. And the flame-failure light is lit.
There is usually a reset button ( plunger ) On the underside of the casing.
Turn off the Power At the Socket ( Spur ) for the Boiler.
push the reset button, If there is One, I,m not familiar with this actual model, without downloading service manuals et,c.
turn the power back on, this may solve the issue as you have reset the boiler And PCB. Also try open-closing An hot water Tap, this can sometimes remedy minor faults, as you are working the PCB, with the possibility Of moving and opening circuits And relays et,c.
Finally if none of this Works for You.
I,d contact Ravenheat themselves, you should find a customer Services number On thier web-Site.
No-One will know, the Boilers better than the company that manufactures-repairs And maintains thier Own products.
I hope This Has been helpful to You. this Information has been Provided To you FREE of charge, by mike @ compurepair.
If i can be of any further Assistance, Please reply to this post.
** Thankyou For Using FIXYA***
Posted on Feb 29, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Hi,\Halsted combi keeps locking out,also no hot water.
could be your pump locking out,or your gas valve.?
does it spark,does it light then go out.
e mail me with what its doing,i will then fix it over phone
Jan 08, 2010 | Combi Centre DX - Mango
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
I have a britony combi se 80. It keeps cutting out, error 60.
hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Sep 09, 2009 | Combi Centre DX - Mango
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
GPS Logo
1,192 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
