Philips DVDR75 DVD Recorder Logo
Anonymous Posted on Feb 29, 2008
DVD 75 Recorder
Picture freezes then jumps halfway thro disk replay.--is this a laser problem ?
  • Anonymous Mar 05, 2008
    thank you accordianman,but this problem persists to the end of the disc.
A
Anonymous
Thanks again accordianman.---diagnosis dead on! --cleaning disc and a blast of air did the trick.
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Feb 29, 2008
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328491
Points
1751
You may be seeing the results of what the laser has to do about midway through a movie, and that is the laser coming to the end of a disc, then re-focusing onto the second layer of the disc which takes a second, in order to "backtrack" the disc and complete the show. Normal on all sets, and is the nature of the beast. Some higher end players don't do this as obviously due to larger "buffer" memory to help "smooth" over any delays in pix and sound...accordianman
  • Michael Borelli Mar 05, 2008
    Okay, then. You therefore, are having a problem with either dirt or the laser assembly needs an alignment tweak...accordianman
During playback picture freezes
it's having trouble reading the disk. clean it. use a disc cleaner from walmart or radio shack to clean off the optical lens, too..
1helpful
2answers
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Pixellated and freezing
hi most of the time a cleaning disk or canned air is not enough but you can tray it, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
bye and good chance.
Picture stalls/freezes
Clean laser lens with canned air Then clean the rubber circular area off (part that disc fits onto) then try to see if it stops freezing &skipping.
DVD Picture jumps and freezes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
"freezes" halfway through dvd
sounds like theres an obstuction with the slider rail. This is the small metal bar that the laser assy rides on. Also check the drive system. It could be a gear to gear system or a belt to gear system. There could be also a cable blocking the laser from tracking. This is a hard call without seeing the unit But you have to remeber to unplug the unit before taking odff the top. Good Luck
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
