Question about Panasonic Televison & Video
Panasonic SA-HT990 cinema unit. All connected ok but speech seems overshadowed by other sounds. Unit is turned up about half way
myob247
  • 1342 Answers
SOURCE: When turning on my Panasonic
Have to agree with bestdarngood and Benimur that it is the voltage regulator.
Here is good troubleshooting guide.
May come in handy also if you choose to take it to a service technician.
Posted on Apr 21, 2008
Benimur
  • 6966 Answers
SOURCE: panasonic home cinema model sa-ht75
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
ravichetty
  • 158 Answers
SOURCE: CAN'T FIND A CODE FOR MY SA-PT460 PANASONIC HOME
PRESS STOP ON UNIT + THE MORE THAN 10 BUTTON ON REMOTE. UNIT WILL REINITIALISE
Posted on Jul 27, 2009
sonicboomele
  • 1557 Answers
SOURCE: Panasonic SA-PT480 will not turn on after power
it sounds to me like you have endured a power surge and it has cooked the unit // i would replace it as surges do so much damage it normally writes the unit off but your power company is liable to replace it (if it was a surge)
Posted on May 15, 2010
SOURCE: Panasonic SA-HT820V need universal remote that can control radio
I had a similar problem. I disassembled my remote (flat screwdriver and pulling, cleaned the circuit board and rubber buttons thoroughly with rubbing alcohol, then reassembled.
For some reason, the remote didn't work properly until I started pressing the channel buttons immediately followed by the volume buttons. It worked normally, after that. It was most likely due to the not yet dry rubbing alcohol interfering. My remote now works, normally.
Posted on Sep 05, 2010
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
ยท Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Feb 03, 2010 | Panasonic SC-HT500 System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
CAN'T FIND A CODE FOR MY SA-PT460 PANASONIC HOME CINEMA, CAN I GET YOUR HELP PLEASE
Jul 12, 2009 | Panasonic Televison & Video
Panasonic sa ht990 fault 61
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | Panasonic Home Theater System System
PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Aug 01, 2007 | Panasonic SC-DT100 System
Televison & Video Logo
414 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
