Question about Edimax BR-6104 Broadband Router. One 10/100M WAN Port and 4 10/100M LAN port.
Configuration of the edimax 6104 broadband
Hi guys,
I have connected the router through the cable modem (Thomson) to the internet, and my main pc is connected to LAN1.
I succeed using the original dialer (which worked with the cable modem before I connected the router), to get online with the ISP.
The problem is that when I open the browser and try to call a website, nothing is working, and I receive a message as if I am off line.
I suspect that there is a firewall configured in the router which blocks the browsing.
How can I solve that problem?
P.s. I dont have any disk or software of the router.
Thank you and best regards
Alain
  • 47 Answers
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Regards
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
Configuring
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
EDIMAX IEEE 802.11g 54Mbps
hello!
May 06, 2008 | Edimax 4 Port Wireless AP Broadband Router...
Always disconnect
hello!
Apr 17, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Linksys Modem
To confirm that your PC is connected to the router, open a browser and type 192.168.1.1; In most older LinkSys routers, the default username is none/blank and the default password is "admin." Most current Linksys routers,  the username and the password are  "admin."  Once inside the configuration page, click on "Status"; Verify that your Internet Connection has got some numbers such as IP Address, Subnet Mask, Default Gateway, DNS & MTU.
If none, your router cannot connect to the cable modem, if yes, pls post back the numbers/details. Further, pls add brand/model of your cable modem and your ISP.
In the meantime, you may have to check that all the cables are correctly plug in and that your cable modem & router are getting power from the mains.
Hope this be of some help/idea. Pls post back with additional information.  Good luck and kind regards.
Nov 01, 2007 | Linksys Wireless-G Broadband Router
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Oct 25, 2006 | Edimax BR-6104 Broadband Router. One...
Computers & Internet Logo
725 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
