My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to unlock it does not open the door even when machine switched off. is there any way to solve this? we are prepared for the water pouring out! he just wants his clothes....
The washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Posted on Feb 29, 2008
Hoover 500m top loader washing machine fails to stop at 'OFF'
timer and dont think u can get them any more
Jan 18, 2013 | Washing Machines
Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Jul 15, 2012 | Hoover Washing Machines
Hoover performer 1200 ac120.what size is the washload?
Have a look at the manufacturer's panel, probably on the back- it might give you an indication there- or your manual?
Just in case-
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
Another possibility would be to go onto the manufacturer's web site DIRECT to see, OR your (intended) vendor's site?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 26, 2011 | Hoover Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Hoover 1200 performa dosnt seem to be getting hot? the drum feels cold when washing, any ideas?
Morethqan likely a faulty heater element, this is located a t the bottom rear of drum, remove rearr panel of washer to access, you will need a meter to test it.
Feb 07, 2010 | Washing Machines
How to work the hoover performa 1100 washer dryer
My Hoover Performa 1100 does not drain the water therefore it does not open. Can anyone help please?
May 15, 2009 | Washing Machines
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
