I had the same problem an E20 error. Took apart drain hose cleaned and then took apart drain inside machine. Rubber ellbow boot was clogged to the max. I crossed fingers and ran a load and tada!! everything good!!
Was this solution helpful? Show your Appreciation by rating it:
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
