Question about Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum
Dyson DC08 Poor suction Even after filters are cleaned,no pipe blockage,no splits Thanks Anne
  • 1 more comment
  • berg01 Nov 24, 2008
    Exactly - got to buy another vacuum cleaner if no solution.
    I have cleaned all Filters, checked the pipes and the hose - everythng is OK.
    I also tried without the dust container to clos the hole to the motor by hand and found high vacuum - but when using the full system there is almost nothing at the end of the nozzle.
  • Anonymous May 02, 2009
    same problem as above, it seems the head is not working properly. the brushes are not turning and no suction.
  • Anonymous Mar 28, 2014
    I have cleaned the filters and charged it
    Welcome Back:
    Visited the website for 2 consecutive days.
I managed to take the cyclone apart. here is some help with what i did I hope this helps. You will need a philips and torx screw drivers. Especially torx with T - handles and thin shaft makes the task much faster and easier.
1. first undo the screws holding the top handle.
2. lift that part of the handle and pull towards the other end of the handle at the same time. Care this is a tricky manoeuvre but the other end is just sloted in. sometimes may be glued so some force may be needed. see photo 1
3 Once the handle is off. there will be screw under the end that you pulled off. undo that screw. see photo
4. Now turn the cyclone upside down. Pull the cone off. this is only a push fit and should pull off
5. Now you should be able to see the three torx screws holes as indicated in the photo.38c6322.jpg
6 The removal of these torx will enable this section to be pulled off exposing one more layer with three further torx screws to be removed as indicated in the next photo7a60cdc.jpg
7 Once the final torx screws are removed, turn the cyclone upright and the top bit which held the handle should come off exposing the complex combe structure. see photo 92fa764.jpg
8 Then you should be able to lift the combe structure as well see phoDyson DC08 - 349cdfc.jpg="http://i.fixya.net/uploads/images/349cdfc.jpg" alt="349cdfc.jpg" class="h_mi" />
9. and final photo of all the part that Dyson DC08 - d6aa9d9.jpgpart d6aa9d9.jpg
10. Thoroughly was all the parts with water and make ABSOLUTLY sure that the part are dry before putting it altogather again. Your vacuum will be as good as new. mine was. good luck and happy cleaning.
Posted on Apr 11, 2009
I found this on e-Bay. Pattern (non-Dyson replica) pre-motor filters are only a couple of quid so worth a try!
"A common problem found with the DC08 and DC11 cylinder cleaners is a notable loss of suction that seems to remain despite cleaning the filters. If you have such a machine and have noticed that the performance has dwindled, you might also detect a dull 'pop' approx 1 - 2 seconds after the appliance is started. This is the internal by-pass valve operating which is there to protect the motor from becoming starved of air. Instead of using just the suction air from the vacuum hose, the air is now coming into the machine from around the body. The problem lies within the pre-motor filter yellow casing which, unlike the older Dyson models, has a double low micron membrane which has a tendancy to clog once the micro-dust gets inside. This is great news until you actually want to wash the dirt out. The pores, once clogged are so efficient that even water cannot pass through them. A simple test is to first of all, fill the yellow filter with water (with the blue sponge removed) and hold it up. If the filter is clear, the water will run away, if not, the water will either slowly drip away, or may not even drain away at all. If you also hold the filter up to the light, you will see daylight through it if it is clear, and the extent of the blockage if not. There are only really two things that you can do. Either scrub away with an old toothbrush until you can get the water to run free through the filter, or replace it. Dyson DC08 pre-motor filter."
Posted on Apr 09, 2010
  • patricias919 Sep 04, 2010
    I took your advice but also got my husband to blow out the hepa filter with his compressor, without dismantling it.
    I can hardly believe the diference, the brushes spin easily again and it hangs on to the carpet and cleans like it should, thank you
  • jkankaanpaa Dec 19, 2010
    Thank you so much Johnboy, I had the suction loss problem too and I thought I had washed both of the pre-motor filters, since according to Dyson instructions you can like rinse them off and then you'll be fine again. Bah! The blue sponge maybe, but the other one enclosed in the plastic housing... after reading your tips I realised it was completely clogged with dust, no daylight showing through, and I went at it with a brush. With serious scrubbing I finally managed to get some of the dirt off, and after it had dried I put it back on. The performance was considerably better so it seems that was the root of the problem indeed. There's no way I'm going to get it all clean so I've already ordered a spare. The whole scrub/wash thing is quite poorly documented, and I think there are people at Dyson who deserve a stiff telling-off for this.
There is a HEPA post-motor filter that Dyson claims is a lifetime filter that never needs cleaning or replacing. Their literature does not show how to access it but it is pretty easy by prying off the plastic cover which is hidden under the primary filter compartment.
However it will plug with fine dust that gets through or around the primary filter. The HEPA filter cannot be washed like the primary filter. If it is plugged you may have to buy a replacement. I was able to tear off the membrane that covers the pleated HEPA filter and that removed most of the dust plugging the machine. It works fine now but I will probably have to buy a new filter if it plugs again.
I am surprised no one has filed false advertising charges against Dyson. Their literature and even the printing on the vacuum boldly state that this is a lifetime filter and never needs cleaning. However they have the filter for sale if you call their 800 number and if you do a google search for " Dyson HEPA filter" you will find a lot of suppliers that sell replacements for this filter. Obviously there is a significant market for replacements clearly proving this filter does not provide a lifetime of service. When I called Dyson they said that they do not guarantee their "lifetime" filter will provide a lifetime of service.
Posted on Jun 16, 2009
    Problem Solver:
  • 7 Answers
Also try taking out filters and see if sucks without them My dyson animal only works with the prefilter removed I put a new one in a no suction at all so worth a try
Posted on Jul 27, 2009
The Cyclone is blocked - go to http://tinyurl.com/bgajnl and follow the instructions - you'll need patience and some "torx" screwdrivers, but afterwards your Dyson will be good as new. It's worth it.
Posted on Feb 02, 2009
  • 75 Answers
So much for never losing suction, huh?? Try the reset button.
Posted on Feb 29, 2008
Thank you so much to solution number two guy. We did it and now I have a cleaner that works again after two years of moaning and changing filters. I hate to think how many Dysons broke to get to those helpful pictures. and to find the invisible screws. The holes at the top of the cyclone were plugged with thick hard dust.
Guess they are not up to country houses with log fires and messy boys. At least we can now fix the problem if it clogs up again. I'm getting a Henry next time.
Thanks again
Posted on Apr 05, 2010
My Dyson Vacuum DC24 suction loss.
You sound pretty savvy in your troubleshooting. Take a look at this video. You may have a split in one of your three suction hoses. I tried to find a video for a DC24 but to no avail. These two models are pretty close and this video should help you out.
Dec 04, 2017 | Dyson Vacuums
Suction on my dc08 is very poor when turbine head is attached - no problem when not. I have cleaned the brushes an ensured there are no blockages. Why the loss of suction when using turbine head ?
please go to the web page www.dyson.com and go next
http://www.dyson.com/support/help.asp?article=1468&product=DC22-TURBINEHEAD-US
and fix it. with commong sense.
God bless you
Jul 19, 2012 | Dyson DC08 Cylinder Bagless Canister...
Vacum cleaner has poor suction
I'm sorry to hear your DC08 isn't picking up as well as usual. This may be due to a blockage in the floor tool, wand or hose, and the filter may also need a wash.
To locate and remove any blockages in the machine, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc08/dc08-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/check-the-floor-tool
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely somewhere warm before replacing it.
I'm confident this will resolve the issue, but if you'd like any further assistance or advice, please call our customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Mar 28, 2012 | Dyson DC08 Cylinder Bagless Canister...
Loss of suction in dyson dc08
If your DC08 doesn't seem to be picking up as well as usual, there may be a blockage in the machine. The filter may also need a wash.
The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc08/dc08-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/check-the-floor-tool
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call us on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Mar 03, 2012 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
Dyson vacuum cleaner model DC08 lost it's suction
Hi Noel,
I'm sorry to hear you're having difficulties with your DC08. If the machine doesn't seem to be picking up as well as usual, there may be a blockage somewhere - the filter may also need a wash.
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve the issue, but for any further assistance or advice, please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Jan 06, 2012 | Vacuums
There's no suction power
I'm sorry to hear you're having difficulties with your DC08. If it's not picking up as well as usual, there may be a blockage in the machine, and the filter may need a wash.
http://www.dyson.co.uk/support/help.asp?article=300&product=DC08-SY-STD
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
You should find this resolves the issue - however, if you'd like any further assistance, please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Nov 19, 2011 | Dyson DC08 Cylinder Bagless Canister...
Dyson Vacuum Cleaner has ample suction without main attachment connectewd to pipe. Have had head dismantled and it is free of blokage but has no suction when fitted. The carpet brush spins freely but the...
I'm sorry to hear you're having difficulties with your DC08. If you're concerned about the performance of the turbo head, you may find it helpful to check the cleaner for blockages, and to wash the filter. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=300&product=DC08-ST
The correct way to wash the filter is shown in the video below. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and ensure the filter is totally dry before replacing it - this may take up to 12 hours.
Hopefully, by clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned that the turbo head doesn't seem to be working correctly, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and to recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Aug 28, 2011 | Dyson DC08 Cylinder Bagless Canister...
The suction on my DC08 feels like it is down to 10% to what it was when I had it new. I had a similar problem about 2 yrs back and even changed the head unit. It worked fine for a few months but has...
Some of the dyson units strip down further using torx bits, sometimes the internal holes of the plastic components get clogged with fine dust that hardens, causing loss of suction. Although the filters are cleaned regularly the airflow is reducedthus giving poor cleaning power.
Aug 04, 2011 | Dyson DC08 Cylinder Bagless Canister...
My DC08 dyson doesn't seem to have the suction it used to have, is there anything I can do to get it back
Poor suction is almost always caused by a blockage of some kind. You need to check all the pipes and hose, and remove any obstruction. You also need to check the filters - particularly the washable filter - and make sure they're clean. If you wash the washable filter, it's vital that you follow the instructions about drying it - if you use it when it's even slightly damp it can clog badly. If in doubt, get a new filter.
Feb 12, 2010 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum Logo
5,048 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
