Question about LG VX-8700 Cellular Phone
Ring Volume is too Low
I am missing calls because the ring volume is very low. I have set the master volume to high. The ring volume is good when I am 'selecting' the ring tone and hitting 'play' to test it, but after it is selected and someone calls me, the volume reverts to very low. Has anyone else had this problem? Could it be my service provider which is Verizon?
  • 2 more comments
  • lindaclc Feb 29, 2008
    I need more information. "Sound is very low" doesn't tell me anything. Thanks for any more assistance you can give.
  • zonia Mar 09, 2008
    user guide on how yo use this phone
  • Anonymous Jun 15, 2008
    cannot hear phone ring unless very close to it
  • RDTODD Jul 03, 2008
    my samsung phone ring tone is very low. it is set on high but the volume is hard to hear even when testing. if it is you pocket or purse you never hear it ring. have set master ring volume to high and also tried vibrate and ring setting.
Sound is very low
Posted on Feb 29, 2008
    New Friend:
  • 3 Answers
This may help iphone volume = go to seting, then general, then find ipod, turn off volume limiter , and raise the ipod volume to max, see if this helps..
Posted on Jan 09, 2013
My phone will not ring anymore - neither the handset or the base unit. There is no menu button to push. HELP!
You can select the ringer volume to HIGH, MEDIUM, LOW or OFF on the handset and the base unit separately. The factory preset is HIGH. If set to OFF, the unit will not ring for external calls and will ring at the LOW level for intercom calls.
1. Does the phone dial out ?
If yes go to next question. If No check line.
2. Do the displays flash when the call comes in ?
3. Is the volume setting too low.
either way refer to manual attached here Panasonic KX TG5100M Operating Instructions Manual
Mar 11, 2016 | Panasonic KX TG5100M Cordless Phone
Does the Siemens Euroset 805 have a high low volume switch ?
Thanks M.Qasim for the solution!
Just a small correction you have to set the phone while is ringing. I did the following sequence call to the pone then press "Set" "#" "4" "#"
Oct 28, 2012 | Siemens Euroset 2005 Corded Phone
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
Nokia 5530 call soud is very low
Open setting , open tones and set the volume up to the high level
make a test and redo if required, choose a caller ring tone that is good to recognize.set the tone pad levels.
the volume level of the caller in the speaker can be increased when the call comes using the up and down keys of the menu scroll which show s an indication on the screen. If low check the earpiece for dirt or weakness of the unit.
Sep 29, 2010 | Nokia 5530 XpressMusic Smartphone
My phone doesn't ring to maximum volume, its too low.
Welcome to FixYa
Dear User,
You can Adjust your Ringer Level to High...If your Ringer is in Full Volume and No Sound/Bad Sound-the Problem is with Buzzer or Board Complaint[Board complaint in Rare Case]
Ringer Option in 6300:
  • Settings
  • Profile
  • General
  • 'Personalise'
  • 'Incoming Call alert'[Must be in RINGING]
  • Move to Bottom 'RINGING VOLUME'[move to Right side-now you can Hear Sound-Set to High Level or as you Like
  • It may ask for Confirm Selection of high Ring Vol
  • Alert For 'ALL CALLS'[at Bottom]
  • 'Save' Click
  • Then Activate GENERAL
You are Done[In this way -you can Select any Profile]
Hope this Helped -Dont forget to Rate ME......Thanks for Contacting FixYa...
Jul 09, 2010 | Nokia 6300 Cellular Phone
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
1 Press {MENU}.
2 Scroll to “Ringer setting” by
3 Scroll to “Ringer volume” by pressing
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
My ringing volume is very low i have tried advanced profiles and put all setting on high however its still very low i can hardly hear it.
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
Oct 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Volume is set for loud but can hardy hear it ring on my
make sure you check all your settings just because your volume is set for high your call ring might be low
Jan 05, 2009 | RIM BlackBerry Pearl 8100
LG VX-8700 Cellular Phone Logo
846 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
