Question about Dell Dimension 3000 PC Desktop
Limited lan connectivity - Dell Dimension 3000 PC Desktop
Any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare
Posted on Oct 16, 2008
May be there is some problem with some lan driver ..
or try re-installing that driver ///
this may surly help u ..
or do check the lan cable...
:d
dushmis
    Problem Solver:
  • 12 Answers
Try power-cycling your router and/or broadband modem and seeing if that brings your network back up for you. If that doesn't fix it there could be a variety of related issues such as a corrupted winsock, that sort of thing.
If simply power-cycling the equipment doesn't work let us know and we'll move onto the next step.
Posted on Feb 29, 2008
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Limited or no connection
Limited connectivity
If you get a 'Limited connectivity" on you LAN connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the router.
To fix this problem, right click on the LAN icon on the Task bar and then click Repair.
This will force the router to issue a IP address to the LAN card on the laptop.
Feb 11, 2013 | Computers & Internet
Lan cable is connected but i have limited access and no internet connection
You first check type of your internet. Is it through LAN or other way?. If it is LAN through your broadband router plz select obtain IP address automatically in LAN settings. It will solve your problem
Sep 18, 2010 | ASUS P5P800 SE Motherboard
CF19 LAN connection problem
Hello there, have you check your LAN IP?Make sure that your LAN IP is uniqe from other pc on your LAN otherwise your connection will be limited.
Mar 28, 2010 | Panasonic Toughbook 19 Laptop Convertible...
LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Jan 23, 2010 | Linksys Wireless-G Broadband Router
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Unidentified network which has limited connectivity
You're network card may be disabled, and that would be why you are unable to connect to yout network/the internet through your network card, to check this go to your network settings, right click on the "Local Area Connection" and if the option is there to "enable" then click it because your card has been disabled, if disable is there in stead then I'm stumped. with regards to "unidentified network" This usually comes up when someone has a wireless network created, but they have the settings made to not broadcast (show) the SSID (name) of the network. This is done for extra security, because in order for someone to connect to the wireless signal they need to know the type of encryption used, the key or passphrase for the encryption and on top of that the network name. Limited connectivity means that you are "connected" only in the sense that you can see the network connection, but you are unable to do anything with it.
Oct 14, 2009 | Linksys WRT160N Wireless Router
Lan troubleshoot
If the LAN status says limited or no connectivity it only means one thing the PC is not getting a valid IP from the router , first thing to do here is that was working fine before is to restart the computer and if after that still not working restart your router and your modem to refresh everything...
Jul 10, 2009 | New Media LANSurfer 56K/100 (NMC07021)...
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Connection problem
You router is not issuing DHCP - set your LAN port on laptop to a IP in the same range as the router
Apr 06, 2008 | SMC Barricade g SMCWBR14-G (662698582192)...
Dell Dimension 3000 PC Desktop Logo
119 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
